JD X530 verses X360 purchase ?
   / JD X530 verses X360 purchase ? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
I currently own a 2011 JD X740 (diesel).Neighbor widow was looking purchase a new JD X360 or X530.I talked her into buying the X530 because she is mowing 3-4 acres per week.She also wants to buy a front mounted snow blower for the X530.You folks who have owned and operated a JD X530 are you happy with it? I hope I steered her in the right direction going with a bigger garden tractor verses the X360.The price difference was $1340 between the two units.
   / JD X530 verses X360 purchase ? #2
Thex360 has a serviceable transmission. I think, not positive, but I think it's the same frame too. If you're not running a tiller, x360 would be fine
   / JD X530 verses X360 purchase ? #3
the diff lock will be the biggest difference, that and a slightly larger tire will give
the 530 better traction with the blower. she should do fine with it!
The frame seems larger on the X530 verses the X360.But I could be wrong.
   / JD X530 verses X360 purchase ? #5
Very likely you are right. Form follows function.
   / JD X530 verses X360 purchase ? #6
I faced a similar decision last spring. I went with the X500 primarily due to the differential lock feature. My primary use is grass cutting, pulling a 900 lb lawn roller, and pulling a JD 17P cart.
   / JD X530 verses X360 purchase ? #7
360 has the K58 medium duty transmission.
500 series has a heavier K66 with diff lock
Caution the 100 series, 300 and 304 have the dismal K46 transmission. Stay far away.
   / JD X530 verses X360 purchase ? #8
With 3-4 acres plus snow blower, the X530 is a better choice. I have X500 and recommend it highly.
I hear ya.I own a X740(diesel)and thats one of the reasons I steered her towards the X530.
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2008 Dodge Ram 1500 (A50515)
2008 Dodge Ram...
1268 (A50490)
1268 (A50490)
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2017 Claas Jaguar 860 Forage Harvester (A52128)
2017 Claas Jaguar...
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
