mark4708
Hi Everyone.
I have an issue with my JD X530 54" deck, only one side will rise.
This started after I hit a rock, replaced the blades and noticed that ROD, part # M164280 was bent.
I also had to replace the lower raise handle - it snapped off.
So, after installing the new rod (one on each side, just to be safe) and leveling the deck I set off and did a test cut.. I noticed then that deck would not rise on the side where one of the new RODs was installed - the ROD had popped out of the plate.. I re-installed the ROD and the same thing happened again.
Because the ROD had popped out, the deck will not rise on that side.
If I just drive the tractor around without cutting and raise and lower the deck, there is no problem.
This only happens when I cut the grass, the ROD pops out.
As far as I can tell the ROD is installed identically on both sides of the deck.
I would really appreciate any help on this.
Thanks,
Mark
Thanks,
Mark
