efultz
I have a X500 - great tractor except for one really big issue. Sometimes the tractor runs just fine. Other times, usually after about 15 minutes or so, tractor will begin surging and stall under load (when blades are turned on). For a while holding choke will get it to stop surging but once under load it will, eventually, stall. I am, often, able to get it to run smoothly if I take the air filter completely off and sit on the tractor for about 2 to 3 minutes holding the choke and, gradually, lessening the choke. After a while the engine will smooth out. I have had this at the JD dealer who just cleaned things (not exactly sure which things). We have a bigger JD dealer who services the big tractors and I am thinking about taking this baby there on the theory that if they work on the big boys they should be able to resolve this little guy. From what I have read it sounds as if there may be something getting in the carburetor or fuel line? Fuel is good as I run this in the winter, also, with the snow blower. It has similar problem then. The thing is this does not always happen but when it does it is a real problem. And, sometimes, I am as far from the barn as I can get when it happens.
Thoughts what might be the issue? How can I resolve this? Other than this really big issue the tractor has been very good for us. We have about 5 acres of land including horse pasture and such. So, when the tractor is working it gets a workout. I keep it in the barn - not outside in the rain or snow (most of the time).
