JD X304 VS CUB CADET 2542
   / JD X304 VS CUB CADET 2542 #21
I would say backing of a cart with AWS might be a challenge. If you get a test drive from your dealer, maybe he will also let you "practice" backing a cart. Myself, that wouldn't be a factor in my decision. The X304 with it's AWS would get my grass mowed, I'm assuming, quicker than the Cub. If you were planning to handle ground engaging equipment, then I would go with a GT.
Thanks "ALL" for your help. I just brought home the Cub GT2542. The main reason I did this was for the extra weight of the machine and for its (IMHO) heavy duty transsmission. Also the shaft drive was an added bonus. As I said I only mow 3/4 of an acre but I have another acre and 1/4 that I might want to clear. There is a nice waterfall on my property that maybe someday I would like to clear a little of that land and build a cabana on. I think the Cub might have some ground engaging equipment in it's future as treet put it. Bottom line is for my situation I could grow into the Cub but the deer x304 I think I would have grown out of. Now if I would have moved up to the deer 500 series or found a used AWS 400 model, that may have been a different story /forums/images/graemlins/smirk.gif
   / JD X304 VS CUB CADET 2542 #23
Well you could have really grown into a Cub 5000 series /forums/images/graemlins/wink.gif
Enjoy your new tractor /forums/images/graemlins/grin.gif
Well.. I had made a deal on the Cub....Even brought it home. But it turns out that the Cub on hills was MUCH to unstable. Why you ask? Center of gravity. Operator sits to high in the air. The Cub dealer took the mower back as I did not even cut a bade of grass with it. A VERY good dealer I might add! The Cub looked great on paper but the x304 Deere AWS was the ticket for my situation. Much lower to the ground. Also a little wider. Don't get me wrong you get a good bang for the buck with the cub (and built like a tank) but the Deere was the right tool for the job! As other people have stated, TRY BEFORE YOU BUY!! Lesson learned...
   / JD X304 VS CUB CADET 2542 #25
I just went through the same decision making process. I got a lot of info by reading this thread.
My yard is sloped also and I researched both the Cub 2542 and the JD X304.
I saw that Consumer Reports rated the X304 as best on sloped and hilly yards.
I was lucky that my local dealer sells both Cub and JD.
He offered to let me try out both machines. He delivered them and we put them both through all the paces.
I also felt much more stable and secure on the X304. It was no contest. The Cub felt more prone to tipping on the more severe slopes.
The JD felt stable.
So I bought the X304. They delivered it this am.
Thanks for all the help. It got a lot of good info here.
Len in NC
   / JD X304 VS CUB CADET 2542 #26
jj1 said:
Thanks guys for the info.
Is there anyone who owns one of these machines that can give me a thumbs up or down?
The JD 300 series are lawn tractors.
The CC 2500 series are garden tractors.
You need to move on up to the JD 500 series to get something comparable to a CC 2500 series.
I have a CC GT2554 That I like real well but I'm selling It because I replaced it with a new BX1500.
I wanted to move up from the garden tractor to a Sub-Compact.
   / JD X304 VS CUB CADET 2542 #27
jj1 said:
1*I think the Cub might have some ground engaging equipment in it's future as treet put it.
2*The deer x304 I think I would have grown out of.
3*But it turns out that the Cub on hills was MUCH to unstable.
4*but the Deere was the right tool for the job!
1*How are you going do what you said in #1 with the 304 lawn tractor?
2*And when you grow out of the 304 what then?
3*That's strange Seeing as how my CC GT2554 has excellent stability on hills in fact that's why I have it for mowing my slopes.
Yep very strange indeed.
4*Until you grow out of it as you stated in #2.
   / JD X304 VS CUB CADET 2542 #28
1*I saw that Consumer Reports rated the X304 as best on sloped and hilly yards.
2**I also felt much more stable and secure on the X304. It was no contest. The Cub felt more prone to tipping on the more severe slopes.
The JD felt stable.
Len in NC
1*This don't really tell me much because it's an apples to oranges test.
2*Like I said you did an apples to oranges test .
There is nothing wrong with the stability of the CC 2500 series.
I bought my GT2554 specifically for mowing my slopes and it does it quite well with no stability issues what so ever.
== L B ==
PS
To come to an accurate reliable meaningful conclusion the comparison must be between 2 garden tractors or 2 lawn tractors.
In yours JJ1s and RDs the comparison is between a lawn tractor and a garden tractor thus causing the misleading or meaningless conclusions.
In my experience over the years I've found that in general:
lawn tractors to feel more stable than garden tractors-garden tractors to feel more stable than sub/compacts -sub/compacts to feel more stable than compacts and compacts to feel more stable than utility tractors.
   / JD X304 VS CUB CADET 2542 #29
nice, i want a 304 myself...someday.....
   / JD X304 VS CUB CADET 2542 #30
Hey LBrown59.......... lighten up.
No one is belittleing the 2542......it's a nice machine. Just didnt perform as well as the X304 on my slopes. Don't take it personal.
"Lighten up Eugene" ! :)
Len in NC
   / JD X304 VS CUB CADET 2542 #31
treed said:
That X304 is not a L/100 series. If you take a look at the construction of the X304 and compare it to the L/100 series, you will notice that it's has a stronger frame and better quality. As for the Cub, that X304 will last as long as the Cub will. I also wouldn't concern myself with the shaft drive versus belt. I had a 1966 JD 110 that was belt driven and it's still going strong and never slip on hills. Same for my 112L and 111, 21 years old and 27 years repectively.
It takes an awlful lot to slip a belt on my belt driven 1966 and 1967 bolens 850s.
The tires will spin before a belt slips .
2022 Coras Predator Steel End Dump Trailer (A56438)
2022 Coras...
XCMG CV83PD (A53317)
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2018 Deere 323E (A53317)
2018 Deere 323E...
