JD X300 Hydraulics
   / JD X300 Hydraulics #1
JETT62
Tunbridge
JD X300
Replaced axle seal. Filled with dealer recommended JD Hydraulic oil. Ran for 1hr and now will not climb small hill with or without mower running. Engine RPM up, no power to climb. Internal oil reservoir filled to specs.
   / JD X300 Hydraulics #2
My guess is that you have air in the hydro that needs to be bled out and then the hydro will need topping up.
You could talk to a Deere mechanic at the dealership. He may tell you how to bleed it. Another option is to determine the make and model of hydro you have and then go to their website. Many of them have downloadable manuals. HydroGear, TuffTork etc.
   / JD X300 Hydraulics #3
Here is a link to the K46 transaxle used in most x300 mowers. At the bottom of the specs it looks to use 10w30 CD engine oil 1.9 liters. I recall some using the synthetic oils too when rebuilding.
Tuff Torq | K46
2803 (A50460)
2803 (A50460)
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
Ih 4300 Field Cultivator (A50514)
Ih 4300 Field...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A51039)
2003 International...
GENERATOR HOUSE POWERED BY TWIN (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
Case 830 Tractor (A50514)
Case 830 Tractor...
