Oct 9, 2013 / JD THROTTLE PROBLEM #1 D DONNYHYLTON New member Joined Oct 9, 2013 Messages 1 Location RINGGOLD VA Tractor JOHN DEERE 318 Why does the throttle lever cut back while running? What can be done to correct the problem?
Oct 9, 2013 / JD THROTTLE PROBLEM #2 adirondackmtnman Platinum Member Joined Jul 10, 2012 Messages 694 Location Black Brook, NY Tractor JD 5045D Should be a throttle friction adjustment...refer to your owners manual for adjustment on your specific machine... Sent from my LGL35G using TractorByNet
Oct 9, 2013 / JD THROTTLE PROBLEM #3 C chickenman Gold Member Joined Apr 6, 2004 Messages 408 there is a friction adjustment on my 3410, the instrament panel has to loosened and the right side cowl taken off
