JD STX38 leaking gas from governor shaft
   / JD STX38 leaking gas from governor shaft #1
G
grease
Guest
I have a JD STX 38 that is running like it wants to stall. It has a real gassy mess and have determined there is a gas (not oil) leak from the governor shaft that comes out the side of the engine. When used last summer, it would stall out when the gas tank got down to 1/2 tank, and then had to refill.
All posts I had read say that it is oil that leaks from the governor shaft, but mine is gas..very strong smell. And over the winter, gas tank went dry.
It was at the dealership 2-3 times last summer for similar carb issues, a rebuild kit installed, then taken back to recheck the float and then back a third time to be told there is nothing wrong with it. And of course having to pay $$$ for a mower that still does not run.
How to fix?
   / JD STX38 leaking gas from governor shaft #2
Is the crankcase full of gas oil mixture? If yes then the carb inlet needle and seat are not sealing properly. When rebuilding the carb was both the float needle and SEAT changed or just the needle? Some carburetors do not allow changing the seat so you either have to replace the carb or try and carefully polish the seat with out making the sealing diameter to large.
Tank going empty over the winter is a good indication that you the problem stated above. Also if the crankcase is full of gas oil mix you can damage your bearings, blow out seals or worst case, gas vapors explode inside the crank case.
2006 FORD F-750 WATER TRUCK (A50854)
2006 FORD F-750...
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A51039)
Toyota 6FGU25...
2006 INTERNATIONAL PAYSTAR 5500I KILL TRUCK (A50854)
2006 INTERNATIONAL...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2013 INTERNATIONAL PROSTAR (A50854)
2013 INTERNATIONAL...
