JD Strongbox or Optima
   / JD Strongbox or Optima #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
Getting ready to buy a new battery for my JD4210 & wondered if John Deere fixed the leaking acid situation from when I bought my tractor in 2004. I would prefer the Strongbox but am timid that they might still leak? Any experiences? Thanks
   / JD Strongbox or Optima #2
I was wondering if the Optima batteries had improved? Several years ago most of my local suppliers dropped the Optima batteries because of too many problems with them failing.
I will change out my JD battery in my 4520 this spring and hope to find an Odyssey battery or the rebadged DieHard platinum battery that will fit.
   / JD Strongbox or Optima #3
I have Optimas in 3 tractors and my pickup. No issues
   / JD Strongbox or Optima #5
This past summer I need to replace the strong box on my 110. I went with the an optima yellow top. So far it's been as good as other optima's I've owned in the past. I did drain it while trying to crank and use the glow plugs but it was -6 so and I had run the tractor in a month.
The issue's I have are self inflicted as I don't run the tractor enough in the cold weather to allow the alternator to charge the battery. And then I get lazy and don't pull the battery to recharge it. The optima was more CCA than the replacement stong box and also cheaper since I had a coupon at the auto parts place.
Matt
   / JD Strongbox or Optima #6
I put a JD Group 31 Strong Box in my Kubota 3 years ago and its worked fine. No leaks, no drips, no cracks, no spills. I was looking at a Group 31 Odyssey but then I found the price - Wow. The JD Strongbox was $195 - the Odyssey was $395.
   / JD Strongbox or Optima #7
Optimas if deeply discharged below 10.5V need a special charger to recover them or parallel a good battery. A standard old time charger won't recover them. The link above has a post in it talking about that. Some people think they are bad and they are not.
Also see tech tip 2 and 3 (mostly 3) in link below
Support - Battery Care - Tech Tip Articles | OPTIMABATTERIES
   / JD Strongbox or Optima #8
I had one Optima battery, it came in my RTV900, and it went bad in the second year of life. I replaced it with a NAPA battery since I was at NAPA (authorized Optima dealer) and they didn't have any Optima batteries. He said they didn't stock them because of the price and most folks wouldn't pay the high dollars for them. The NAPA is going great over 3 years now with lots of starts and quick less than 5 minute runs.
   / JD Strongbox or Optima #9
Was an attempt made to recover the Optima per the link above? Normal battery chargers can't charge them if they drop too low.
   / JD Strongbox or Optima #10
That is a good question^^^^
I use three stage marine battery chargers on my batteries designed to work with agm and other deep cycle batteres including gel type. It could be the reason some people are experiencing problems with the Optima agm batteries is they have the cheaper chargers.
I have had good service for everyday use from Walmart ever start batteries where these are not expected to sit for long periods of non use. Fpor my boat and camper I prefer the odyssey and die hards much better for storage and longer intervals between use. My small truck camper has the NAPA gel batteries and these work out great for it.
2008 Chevrolet Malibu Sedan (A51694)
2008 Chevrolet...
2006 Silver Star 8'x102" 5 Horse Trailer (A50123)
2006 Silver Star...
2016 Isuzu NPR Beverage Box Truck (A51692)
2016 Isuzu NPR...
2000 Wabash National 53ft T/A Dry Van Trailer (A51692)
2000 Wabash...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
