JD Steering
   / JD Steering #1
Simsfarm
Louisiana
JD 4120, Gator HPX
Anyone had a problem with sticking steering on JD 40 series? The rubber boot around the steering column seems to grab on the underside of the steering wheel. I used a little WD, but that only lasted a short time.
   / JD Steering #2
Try a little grease. It will last longer.
   / JD Steering #3
Grease would do it... but if you don't want all the dirt that will collect -- I'd try one of the "teflon" spray lubes.
There's quite a few different ones on the market. I use Triflow quite a bit on things like the ball ends of the 3pt, etc.
The dirt doesn't build up as bad and it will last longer than WD-40.
AKfish
   / JD Steering
Thanks AK - I shot it with some graphite powder today and will give that a few days - if that doesn't work I'll try your advice. We spent several days in Alaska last summer - relatives in Soldatna. Rode the train from Anchorage to Fairbanks, then flew out of Fairbanks. It was about my 10th trip to Alaska but the first one where I could be a visitor! All the rest were Air Force related.
2019 Ford Explorer AWD SUV (A55758)
2019 Ford Explorer...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
(2) UNUSED 18.4-30 TRACTOR TIRES (A54756)
(2) UNUSED 18.4-30...
RoGator RG1100C (A55302)
RoGator RG1100C...
Leeboy 685 Grader (A47477)
Leeboy 685 Grader...
EMS SERVICE BODY W/ SIDE DOOR (A51406)
EMS SERVICE BODY...
