JD SST JD LX ??
   / JD SST JD LX ?? #1
NIXON
Veteran Member
West Sunbury ,Pa.
L3130 hst
A long while back I posted about a new lawn tractor . I was looking at the Huqvarna 1842 . I still have my Craftsman (that I hate but won't quite die ) . So I'm still in the market .
The JD SST get's some rave reviews from consumer reports . But I have some pretty decent slopes to mow . According to the JD web site the Lx 277 would be a better match to my needs . Do any of you own one ? Opinions ?? Thanks, John
   / JD SST JD LX ?? #2
I own a JD LX288 ... 18HP VTwin Kawasaki Gas with a 48C (4ft) deck ... three blades and weighs a ton
I use it to cut 3 acres of finish lawn and 3 acres of an old bumpy hay field. I aerate, drag, leaf vacuum, and pull a 1/2 ton wagon full ot split wood with it too.
Its the goods for mowing.
It twasn't cheap either.
/forums/images/graemlins/grin.gif
   / JD SST JD LX ??
</font><font color="blue" class="small">(
)</font>
Doug , Thanks for the post ! I did the cheap route . Been regretting it since . I don't have near 3 acres to mow . But thanks to my Bush hog ,fel and blade the area is getting a bit tamer ,and bigger . The 277 seems like it'll fit my needs very well .
John
   / JD SST JD LX ?? #4
Before I bought my used JD 318 I was looking at the LX277 very closely. There are a LOT of very happy owners out there, it seems like a good unit. The biggest problem I saw was the price - for not all that much additional money (around $400 more) you could slide into the GT235. 1 extra hp, bigger tires, the same or very similar control layout and if I remember it had a slightly heavier-duty transaxle, and maybe a tick heavier frame.
Stoneham's site has some great detailed info if you want to compare.
JD Consumer Info
Tim
   / JD SST JD LX ??
Tim . Thanks for the post ! Lots of good info on the various JD machines . For me the upper end of what I need V what I want is the 277 . I could get by and be happy with an LT except for fuel capacity . I keep looking at various machines . But I keep coming back to the JD's . A Gt is just a bit too much for what I need . Just want a solid Mower with hst,and 42-48"deck .
There's a Deere dealer about 10 miles from me that pretty much handles lawn and garden machines exclusively . I'll stop[ by and see what we can work out . John
   / JD SST JD LX ?? #6
John, I have had an LX 277 now for the last two years, I use it to mow roughly 3 acres, I pull a commercial cyclone rake in the fall and drag a 17 cubic foot cart when needed.
The unit has performed flawlessly, I does a great job on the grass, is easy to operate and my wife seems to like riding around on it, which leaves me free to play, (err I mean work) on my 790.
Anyway, if your experience is anything like mine you will be extreamly pleased with the LX.
Best of luck in your decision.
   / JD SST JD LX ??
</font><font color="blue" class="small">( and my wife seems to like riding around on it, which leaves me free to play, (err I mean work) on my 790.
)</font>
Thanks for the post . The 277 does seem like the machine I'd really like . Especially if it keeps my wife off my tractor /forums/images/graemlins/smile.gif
She won't go any where near my current lawn machine . Can't blame her for that though . I wouldn't either if I didn't have to mow . I will say to Sears credit ,that they've always come through quickly on parts . But , it seems like i should have my own hot line to them ,or at least get an XMas card for the amount of things I've had to buy to keep it going /forums/images/graemlins/smile.gif John
   / JD SST JD LX ?? #8
John, it's a slippery slope indeed when you keep peaking at what comes next in the lineup! And as Jack confirmed - when I was looking into the LX277 I found a large amount of very positive feedback from very pleased owners. When you get the chance though, do take a glance at the GT235 (especially if, as in my case they were parked side by each!). I checked the Stoneham's info - and the GT's do get the next model up tranny (K71 vs K60-something). I was also worried about the smaller LX tires on my rough lawn. Since the prices were so close it made me lean toward the GT. (While of course glancing over to the next row where the GX's were parked!) /forums/images/graemlins/grin.gif
Tim
   / JD SST JD LX ??
</font><font color="blue" class="small">( John, it's a slippery slope indeed when you keep peaking at what comes next in the lineup! And as Jack confirmed - when I was looking into the LX277 I found a large amount of very positive feedback from very pleased owners. When you get the chance though, do take a glance at the GT235 (especially if, as in my case they were parked side by each!). I checked the Stoneham's info - and the GT's do get the next model up tranny (K71 vs K60-something). I was also worried about the smaller LX tires on my rough lawn. Since the prices were so close it made me lean toward the GT. (While of course glancing over to the next row where the GX's were parked!) /forums/images/graemlins/grin.gif
Tim )</font>
Tim I've been down the buy cheap, buy twice road .
But when selecting a tractor I went down the other road . I had my heart set on a 2910 . But right next to it was a 3130 . The wife looked at both and gave the nod to the 3130 . Saying "You'll be back for that in two years " .
So maybe lighting will strike twice . But, if it doesn't ,I think the 277 will make me very happy indeed ! John
   / JD SST JD LX ?? #10
Tim.. the major diff between the LX and the GT seems to be the latter has hyd. power steering.
For finish mowing, in my opin., this is a bell and whistle option and another level of maintenance complexity perhaps.
For machines this size, with no loader, no 3ph work, it's hard to see the value add for power steering. My LX turns with 2 fingers most of the time BECAUSE of the smaller wheels. I have a 4 foot deck - a very proficient size for a 18hp gas 2wd hydro mower.
BTW, my deck is the 48C where C means "Convertible". Does anyone know what it "converts" to? Never was able to figure this one out.
/forums/images/graemlins/confused.gif
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A51692)
2012 Ford F-450...
2012 Diamond Cargo Enclosed 24FT T/A Cargo Trailer (A51694)
2012 Diamond Cargo...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
