JD Sabre 2048 Deck Belt routing
   / JD Sabre 2048 Deck Belt routing #1
davemskinner
Pulaski, NY
GL4330 HST
Hey All,
My son-in-law has a JD Sabre 2048 and got a stick caught in the belt. The belt flew off and he bent the main pulley. He nor I can figure out the belt routing to put it back together. The manual only shows a two belt setup and his is only a one-belt configuration.
I'm not a newbie to this stuff but this is sure kicking our butts.
Any help would be extremely appreciated.
Thanks,
Dave :thumbsup:
   / JD Sabre 2048 Deck Belt routing #2
Looking for info on your mower. Does the deck have 3 blades?
3 blade belt route: John Deere - Parts Catalog
I am not sure this is yours. Does it look similar?
   / JD Sabre 2048 Deck Belt routing #3
I had that mower.It was a 3 blade unit. I don't remember the specifics, but I thought it had a routing plate on the mower deck. ARE you replacing the drive belt or the deck belt. I am pretty sure you have to take the deck off to replace the drive belt. The mower belt is released by a handle that is pivoted to move a pully toward the outside of the deck.
   / JD Sabre 2048 Deck Belt routing #4
My JD Parts link above: If page shows no information: Do this:
1: Insert in {model box} insert [2048]
2: {Click on} (9102-L2048 Scotts Lawn Tractor)
3: {Click on} (Pictorial Index)
4: {Click on} (85-1-D8 Mower Deck & Lift Linkage)
5: View Picture on right side of page.
On my computer the above link showed everything with 1 click, but when I came back later screen was blank. Sorry. The above instructions should get you to a picture of the belt routing. If not, let the forum know it did not work for more information . Try This Link
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Yes very similar. This is not the layout that my son-in-law had in his manual.
But it does look like the one. The way they show the idlers is a little confusing because the picture shows then as three different sizes but they all have the same "item" number. Not that it matters much. The pic is what I needed.
Thanks sooo much!
Dave
The routing plate is nowhere to be found. I was hoping that the decals kit would have it but it does not. Oh well...
Thanks for your reply.
Another great post! Thank you. I was able to get the picture from your first post.
I have a 1984 JD 950 in my garage that I bought to fix and flip. It had a bad tranny (which I knew). Little did I know that the tranny had already been apart and butchered with a welder. Long story short, almost a year and $3K later, I finally have all my parts and am looking for the time to start putting it all back together. I never would have have thought a 1984 machine would be so hard to get parts for.
I guess it serves me right for just jumping in and not doing my homework first.
Thanks again for the help. I should be good to go. I will post an updateafter we get the Sabre going again.
   / JD Sabre 2048 Deck Belt routing #8
The belt should go from the main pulley to the far left blade, then to the middle, and then to the far right. (if I remember correctly)
   / JD Sabre 2048 Deck Belt routing #9
Dave, that belt routing is highly unusual so I can see why it would be hard to figure out without a diagram. Good luck on getting it back on. Ray
2012 UTILITY VS2RA REEFER TRAILER (A43004)
2012 UTILITY VS2RA...
2017 FORD F-350 (A45333)
2017 FORD F-350...
John Deere 6135E (A44501)
John Deere 6135E...
2016 Chevrolet Tahoe SUV (A42744)
2016 Chevrolet...
Year: 2015 Make: Ford Model: F-450 Vehicle Type: Pickup Truck Mileage: 56,365 Plate: Body Type: 2 (A44571)
Year: 2015 Make...
HYDRAULIC PIPE LAYER (A45046)
HYDRAULIC PIPE...
