JD rear Bagger for 2014 X304
   / JD rear Bagger for 2014 X304 #1
Starwalls
NH
JD X304
Any ideas as where I may find a rear bagger for my new JD X304?
I just can't spend the $1000, the dealer wants.
No, I have not even used it yet, they just dropped it off at my home. They even put it in the shed for me. I wasn't home. Which was great due to it was raining. Great service!
   / JD rear Bagger for 2014 X304 #2
Is it a 42"? I wouldn't think it would be that high w/o a power flow. Should be more like @ 500 or so.
No other source other than Deere.
Yes it is a 42" didn't know they made any other. I really don't understand what you say here, (should be more like @500 or so)????? Also (wouldn't think it would be that high w/o a power flow???
Sorry have no idea what you are talking about
   / JD rear Bagger for 2014 X304 #4
Welcome to TractorByNet!
I moved your thread to the John Deere Lawn & Garden forum. :)
   / JD rear Bagger for 2014 X304 #5
John Deere sells only the power flow "system" for 48" and wider mowing decks. The "system" consists of a blower that mounts to the discharge chute opening on the deck and then gets driven by a new "stacked" pulley that gets mounted to the nearest mandrel in place of the existing pulley; a chute to connect the discharge from the blower to a grass catcher; finally the grass catcher itself that gets mounted to the rear of the tractor. Those systems cost in excess of a grand if you buy new from a Deere dealer. Your other choice is to "piece" it together with parts from E-Bay/Craigslist or the like -- this is the approach that I took. I was able to put together a power flow system for about $325 doing it this way.
The alternative for decks under 48" omits the blower. Those grass catchers ought to run $500 or so new from a dealer. This should be what you need for your 42" deck. You may want to look at E-Bay/Craigslist to see what's available ------
   / JD rear Bagger for 2014 X304 #6
About $550 when I use the JD "build your own" site, that's for the hopper assembly and chute.
   / JD rear Bagger for 2014 X304 #7
Something to consider if you plan on a lot of bagging is to swap this mower for a 300R while new. The 300R is an awesome bagger with a very good built in blower. It will be a much better bagger mower than the x304 will ever be but is not 4 wheel steer. It is about $500 more than a 304.
John Deere X300R Tractor with 42-in. Rear Discharge Deck
2018 JLG SkyTrak 6036 6,000lb 4x4 Rough Terrain Telehandler (A46683)
2018 JLG SkyTrak...
2022 Caterpillar 304 Mini Excavator (A46683)
2022 Caterpillar...
2024 Isuzu NRR 24ft Box Truck (A46683)
2024 Isuzu NRR...
Skid Steer Auger Drive & Bit Set (A47371)
Skid Steer Auger...
2016 INTERNATIONAL MA035 (A48992)
2016 INTERNATIONAL...
2014 Chevrolet Impala Limited Sedan (A48082)
2014 Chevrolet...
