JD quick tach parts.
   / JD quick tach parts. #1
ruglad03835
Farmington, NH
Does anyone know if Deere sells the lower pins and top curled mount for the quick tach system on a 300 loader? I need to build a mount for a snowplow and need these items.
   / JD quick tach parts. #2
Deere has something like what your looking for its called "competitive attachment adapter brackets"
I think the price is $224 and I believe the code is 9070
hope this helps!
5103Owner
   / JD quick tach parts. #3
I belive they do sell a kit but i just built forks and bought the same size solid stock for the lower pins and drilled a hole in each one. as for the top part i bought pipe with and ID the same size as the OD of the top of the loader quick mount. hope this helps.
I never thought about a piece of pipe!!! Thanks
   / JD quick tach parts. #5
Here are the part numbers for the 400 seres loaders, I am 99.9% sure they are the same for the 300 series...
You can check yourself at JDParts
W43359 HOOK, BUCKET ---10.73 USD each
W47211 PIN, BUCKET ---6.33 USD each
I built a FEL Snowplow and a Forkfift set with these.
Thanks for the part numbers kennyd. I just ordered them thru jdparts.com. Now lets see if my dealer has them on the shelf.
   / JD quick tach parts. #7
Yep - these will work for the 300 series loaders as well.
2012 FORD F650 ROUSTABOUT (A52472)
2012 FORD F650...
2013 INTERNATIONAL MA065 CAB AND CHASSIS (A52472)
2013 INTERNATIONAL...
Ford NAA Jubilee Tractor (A53472)
Ford NAA Jubilee...
2014 BOMAG BW 213 DH-4 (A52472)
2014 BOMAG BW 213...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
