JD paint
   / JD paint #1
darrenjttu
Glen Rose, Tx
JD 4300
Has any one ever touched up their tractors paint job by the spray paint that is out there. The black on the metal is easy but what about the fiberglass? I don't own a paint gun and just need to touch up some wear spots and scratches.
   / JD paint #2
G'day Mate and welcome to TBN from Downunder.
Enjoy the site... and have a look, at the bottom of this page, in 'Similar Threads'. You may find your answer(s) there.
   / JD paint #3
You said "by the spray paint that is out there" which doesn't specifically say John Deere paint. Your chances of a match are really poor if you get a non-JD brand that just says JD green. And a perfect match using a spray can is iffy from my experience.
But the JD spray cans have good nozzle tips and are your best chance.
   / JD paint #4
I had some paint damage to my loader frame and sanded it with a couple finer grits of sandpaper. I used John Deere spray paint to spray the entire part and it is impossible to see the difference. On a plastic part I sanded the damage and feathered the sanding in with the finer sandpaper. I carefully sprayed with Deere spray can paint and it's very hard to see the difference. Each part I painted got two or three coats with fine grit 300/400 sanding in between. Prep is the key and factory paint only or don't bother.
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
