JD or aftermarket
   / JD or aftermarket #1
nelsont
New Auburn,wi
JD 4410
Just bought a 4410 JD should I buy a JD loader or go after market. The tractor is loader ready.
Tim
   / JD or aftermarket #2
What do you mean "loader ready"? Do you mean it's got the mid SCV's?
Either way, I don't like putting aftermarket loaders or backhoes on tractors, they just aren't made for one another and will not be as powerful or last as long. I believe you can get the newest 300X/CX for them.
   / JD or aftermarket #3
When I was doing my research before I bought a 790 two years ago, I checked on Deere, Bush Hog & Koyker loaders. There really wasn't much price difference between the three. So if had needed to, I would have gone with JD.
I ended up finding an '04 790 w/300 loader. ~~ grnspot
   / JD or aftermarket #4
I would personally recomend a Deere loader myself.
The size loader you want is in pretty high demand, and will be hard to come by used. You can hope to get lucky and find a 300 series (300, 300x,300cx) used or you can look for a 430. Either way you will also need brackets for your series tractor. Chances are the 430 will already come with brackets for your 4x00/4x10 series tractor (but was also commonly found on the 4005, 790, 990's and so on) but the 300 series could be hit or miss as they are more often found on newer series tractors. You can by the brackets separate from Deere, but they are probably around 1,000$.
Here are some I found for you...
1996 JOHN DEERE 430 Loaders For Sale At TractorHouse.com
https://www.machinefinder.com/ww/en-US/machine/1252891
2010 John Deere 300CX Tractor Loaders - John Deere MachineFinder
2011 JOHN DEERE 300X Loaders For Sale At TractorHouse.com
2013 FORD F550 SHUTTLE BUS (A52576)
2013 FORD F550...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
