JD MT Issues
   / JD MT Issues #1
jpowers66
JD MT
Looking for some advice. About six months ago my MT started smoking white. I replaced the head gasket and changed the oil and it's been running great. I went to change the oil again a couple of months ago and it still had quite a bit of water in it. I flushed out the crankcase with diesel and took the pan off and cleaned it. It looked nice and clean on the bottom of the engine. I put the pan on with a few bolts and decided to give it a few of weeks with no oil.
Last night I took the pan back off and there was about a 1/2 teaspoon coolant in the pan. Taking a look at the bottom looks like it might be seeping around the pipe that comes from the bottom of the distributor to the oil pump.
Is that common? I am not sure if there is a seal in there that may need changed or how to proceed and thought I would ask.
Cheers!
   / JD MT Issues #2
:welcome: to TBN
..seeping around the pipe that comes from the bottom of the distributor to the oil pump...
How about a pic of that pipe?
   / JD MT Issues #3
Used to have an MT. I don't think the distributor shaft goes through the water jacket, could be wrong. Sounds like it still may be the head gasket or worse a crack. Hope it's not the latter. You might want to check with the folks at yesterdaystractors.com they deal with classic tractors.
John
2025 CFG Industrial NT18K (A50123)
2025 CFG...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
2023 G Bar K Skirted Hauler Bed (A53473)
2023 G Bar K...
Deere 650J LGP (A50123)
Deere 650J LGP...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2002 Ottawa 30 Spotter Truck (A52384)
2002 Ottawa 30...
