JD LX6 Deck - Water in Gear Case
   / JD LX6 Deck - Water in Gear Case #1
conesminded
John Deere 990
I've just rescued my tractor after leaving it with a person who was supposed to be maintaining one of my out of town properties. It's been several years and I really never got a chance to familiarize myself with it. I bought it from a neighbor, the original owner, and then left it on the property so that it was on site for this person to use. Of course, the poor tractor wasn't maintained the way it should have been.
I've had a friend who works with heavy equipment and an assortment of different tractors come over and do a basic maintenance once over. With the tractor is a JD LX6 rotary cutting deck which has also been neglected. Upon checking the fluid in it's gear case we have discovered that the oil is milky white. I am being told that this is mostly likely because there is water mixed in.
I reviewed the owner's manual for this deck, but there is nothing that indicates how to drain the gear case.Hopefully someone here might has some suggestions/solutions for my problem?
Thanks in advance!
Hilary
   / JD LX6 Deck - Water in Gear Case #2
I sucked mine out using something like this.
Thanks for the suggestion and photograph. By your answer I will assume that there is no hidden plug or such to drain the oil. I am wondering if a small wet/dry vac would work. What is the name of your contraption?
Hilary
   / JD LX6 Deck - Water in Gear Case #4
Sorry Hilary, didn't realize you questioned.
The name ?, don't really know, it was tough to find a pic of one on google-pics.
I believe I used the terms "oil sucker" or something close.
I'll do some search and see if I can find somebody that stocks something like it.
Another pump that would work would be the kind the boat guys use to remove oil from their inboard engines.
UNUSED RAYTREE RMSG29 - 29" STUMP GRINDER (A54757)
UNUSED RAYTREE...
2014 INTERNATIONAL 4300 INSULATED COLD BOX TRUCK (A54607)
2014 INTERNATIONAL...
UNUSED LANDHONOR MGB-72-44W 44" MINI GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
KIDS DIRT BIKE (A55758)
KIDS DIRT BIKE...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A54757)
UNUSED RAYTREE...
2023 CATERPILLAR 299D3 XE SKID STEER (A52705)
2023 CATERPILLAR...
