JD LX188 Kawasaki water pump leak? Only gaskets?
   / JD LX188 Kawasaki water pump leak? Only gaskets? #1
Dave_A
About a year ago I noticed steam from the muffler area and I found that the joint around the water pump was oozing coolant. I added stop-leak and tightened the bolts that I could reach and it stopped. Recently I cleaned the radiator, flushed the system with fresh water, added fresh coolant, and it's leaking again.
1) Will only new gaskets fix it?
2) Do the gasket surfaces deteriorate so that they won't seal to the gaskets and I need a new water pump?
3) Why would this happen after being sealed for years?
   / JD LX188 Kawasaki water pump leak? Only gaskets? #2
And you "cleaned the radiator, flushed the system with fresh water, added fresh coolant" for what reason?
2005 Blue Bird BB Conventional Bus, VIN # 1BAKBCKA45F219634 (A51572)
2005 Blue Bird BB...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
