JD LX 176 charging problem
   / JD LX 176 charging problem #1
b9423w
Rochester NY
JD LX176
I have a JD LX176 that originally had a Kawasaki FC420v engine that was replaced by a B&S model 31B707-0026-E1,about 3 years ago. I am having charging problems and I can't figure out my next move. I can't find the regulator anywhere and I am wondering if it is part of the stator or where it's located. I looked at the ignition switch and saw that it has a circuit board and some components that look like relays and I am wondering if this is where the regulator is located. Any help would be greatly appreciated.Thank you.
   / JD LX 176 charging problem #2
This should help.
View attachment LX172-LX186_E-Component_Locator.pdf
View attachment LX172-176-186_Charging-Circuit-Diagnose_326-327.pdf
Something is not clear to me on the parts.
Go here...
John Deere - Parts Catalog
Search for LX176
Then click on the Sectional Index
Section 15 (Engine 176) and page 8 (Flywheel/Stator) might help...
Then look at section 40 (Electrical) and pages 59 thru 63 show wiring harness options.
I see a voltage regulator that is item 8 in some of the drawings.
But I do not see a board. Maybe you can find what you need there someplace.
BBO,
Thank you so much for your reply it is very helpful.I misidentified the ignition switch,it is called the A2 Interlock module,my bad.The charging circuit diagnosis will also be very useful.The tractor is @ our summer place which is about 60 miles away and I'm not there this week so it will have to wait till maybe Thursday to get any results.Again thank you for the info.
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A55302)
2022 John Deere...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
UNUSED LANDHONOR LHR-WS22 WEBBING SLINGS (A54757)
UNUSED LANDHONOR...
Harrell 3605 (A50123)
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A55787)
2025 68in Dual...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
