Yellowfever, update on my LT155. Upon further exam I discovered the drive pulley was severely worn. I bit the bullet and replaced the double drive pulley ($82 JD) thinking this would surely make a difference. NOT, still the same. After spending more time underneath, it appears the belt is quite loose in the neutral position. It is like the OEM JD belt is about 1/2-1" too long. It can't possibly tighten up. The compression brake spring bottoms out (completely compressed) Everything seems to be assembled correctly. The long tension spring which should tighten the belt seems ok. Very strong but the bottomed out compression spring won't allow the belt to adequately tighten up.
I am completely baffled. My next plan is to lengthen, by about 1/4", one of the ends on the brake compression spring hook ends. It appears to me this would allow the belt tightener spring enough freedom to tighten the belt. My preference would be a new belt that is about 1" shorter.
Sorry to be so long here. JD wants $37.50 just to look at it, 6 weeks out!! Would appreciate any thoughts anyone has on this problem. I mow a lot of farm road shoulder and ditches. I bought a new Cub Cadet last year. I hate it, wished I had stayed with JD. I have a 5205 JD for serious field and pasture mowing. Too big and damaging for some of my ditches and road shoulders.
Thanks for any help, Harold
