Hello, I'm having a bit of a problem with my mower. After sitting over the winter in the basement I had trouble getting it started. Turns out the fuel pump went bad so I went to the local JD and got a new one. It starts right up now but the problem is it takes a few minutes of rough idling before it smooths out and runs good. As soon as I engage the blades it idles rough and about dies. I can disengage the blades to keep it from dying but it will still idle rough afterwards with barely any power to move. I can shut it off and start it back up and after a few mins it will start idling good. I've cleaned out the carb, changed the fuel filter, oil and oil filter, checked the plugs. I can't figure out what else to check unless it has something to do with the pulley under the motor. Would appreciate and help or advice. Thanks.
Forgot to mention I also drained the tank and put new fuel in.
