JD L130 Front Axle Replacement
   / JD L130 Front Axle Replacement #1
wngsprd
Super Member
Beaverdam, Virginia
Kubota L3130 DT
Got back from vacation and the yard was a jungle from the rain. Then found the cast iron front axle was broken in half on my 11 year old L130.
I didn't find anything searching TBN or You Tube on fixing it, and since I was successful today, I thought I'd share here that it wasn't too tough a job, and maybe also save one of you about $250 labor at the dealer.
I was concerned about removing the center axle bolt since it looked like muffler and bracket removal was necessary to give clearance. But the muffler just pulls straight down from the manifold pipes.
So the order of repair was:
1. Remove the hood, pulling the springs off the catches
2. Jack up the tractor
3. Remove the muffler bracket (2 small screws) and then swings down and off
4. Remove the top 3 screws from muffler, and push (wiggle) the muffler down off the pipes
5. Remove old axle pieces, if any remains, and the center bolt
6. Remove steering spindle clip and slide spindle out from each side of axle
7. Slip new axle and bolt in place, and reverse order of other steps
I did not need to remove the front wheels steering linkages or mower deck.
2010 CAT 140M MOTORGRADER (A50854)
2010 CAT 140M...
JLG 1255 Telehandler (A51039)
JLG 1255...
2021 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2021 JCB HM180T...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
2015 Rogator RG1300B Spreader/Sprayer (A50657)
2015 Rogator...
