JD Hydro 175 - no spark (new coil, still no spark)
   / JD Hydro 175 - no spark (new coil, still no spark) #1
jpilk99
Bolton, MA
1983 Ford 1700, 4WD, 770 Loader, Woods backhoe, Woods brush hog,etc.
Subject above pretty much tells the story. I've checked the ground strap next to engine block (cleaned it, tightened it on solidly). I cleaned the magnets on the fly wheel. Bought new coil (first time I ever encountered a new coil with not connector for the spark plug - but quickly figured out it was screwed on... took old one).
Nothing I do renders a spark. Not sure how to test an ignition coil - when I search the web, I get tons of people with vague processes. So if someone has a logical DIY to test an ignition coil, I'm very interested. There is a Kawaksaki FC420V OHV engine on here.
Thank you so much in advance - very frustrated by this one...
Jay
   / JD Hydro 175 - no spark (new coil, still no spark) #2
If it's like an automobile ignition coil you need to ground the shell of it. An automotive coil will have two small terminals and the central high voltage terminal. Connect power to one of the two small terminals, usually marked +. Run a wire from the high voltage terminal to your spark plug. Ground the shell of your plug to the same ground as used on the shell of the coil. When the remaining terminal of the coil is grounded and then the ground removed you should see a spark at the gap of the spark plug.
   / JD Hydro 175 - no spark (new coil, still no spark) #3
The majority of the 420s had an igniter which failed. You can buy the 80$ Deere one or a knock off, they seem to work. AM132770
I added a ground strap, (tested/confirmed ground), with no impact. Thanks though.
   / JD Hydro 175 - no spark (new coil, still no spark) #5
Have you replaced the spark plug?
Yessir. No change.
After reading Tomplum's comment, I took of the igniter and tested it and it failed the test. Ordered another for $9 and change - crossing fingers that that will do it.
I need to get better at testing ignition coils, (sadly, I don't know how to 'set' my new AstroA1 multimeter to a 20K range for ohms/resistance, but, if I could - then maybe I'd be able to actually test both the old and new coils - prove whether it is or isn't the igniter). :)
   / JD Hydro 175 - no spark (new coil, still no spark) #7
Did you read the user manual ?
Yep. Garbage/confusing/unintelligible. I set the range select knob to the 'resistance' graphic of the ohm/something/arrow&plus/speaker(sound). Then it says to "Set the "Select" button to ___ range" where the same graphic is. There is no such setting when scrolling through the "Select" options once the range selector is on the same graphic.
   / JD Hydro 175 - no spark (new coil, still no spark) #10
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
JOHN DEERE 460M LOT NUMBER 258 (A53084)
JOHN DEERE 460M...
2012 CASE IH 1230 LOT NUMBER 186 (A53084)
2012 CASE IH 1230...
2002 International 4300 Cab and Chassis Truck, VIN # 1HTMMAAP02H548742 (A51572)
2002 International...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A53472)
2014 Yale 3 stage...
2021 JOHN DEERE 8R340 LOT NUMBER 209 (A53084)
2021 JOHN DEERE...
