JD HPX Pulling a GD Manure Spreader?
   / JD HPX Pulling a GD Manure Spreader? #1
KennK
NE Wisconsin
John Deere 3320
I'm considering purchasing a JD Gator HPX 4x4, and one of the things I'd like it to do is pull a ground-driven manure spreader. Here is a link to the spreader's specs:
Our Products - H & S - Manure Spreaders - MS50
I have a JD 3320 compact tractor with a FEL that I'm currently using to load & pull the manure spreader, but the hitching/unhitching with each is a real pain. We're hoping that we could load w/ the tractor and spread with the Gator.
The JD dealer that sold us the spreader (and tractor) said the HPX could pull the manure spreader, but I wanted to see if you had opinions.
Thanks,
Ken K.
   / JD HPX Pulling a GD Manure Spreader? #2
I have had two HPX's and currently have a XUV. They are rated to pull 1300 or 1400 pounds but I have pulled loaded wagons before at 15,000 lbs. I have no doubt the HPX will pull a spreader, I would be more concerned with the hitch weight. The wheels look like their pretty far back on the spreader which would put a lot of weight up front.
I was thinking the same thing. The hitch weight empty is around 400 lbs. I don't think I have anything that will allow me to weight the hitch filled ... and I can't drive it to my local truck scale filled with manure.
I don't know how much composted manure weighs, but it is a lot. The spreader appears to have about a 50/50 tongue weight ratio empty (800 lbs empty w/ 400 tongue weight), so maybe I could do some estimates based upon the % of the box forward and aft of the axle. Maybe.
I do fear its a really big number.
   / JD HPX Pulling a GD Manure Spreader? #4
That looks like the same spreader we use, except ours is the Frontier line from JD. I used a gator 6x4 diesel with our until I got an XUV this year and both handled them just fine. I load it really high too and they handled it just fine.
   / JD HPX Pulling a GD Manure Spreader? #5
i would say pretty much the same things if you can hook onto it and get traction you can pull it . the main thing is the hitch weight try not to go to far over the max weight of the reciever .
   / JD HPX Pulling a GD Manure Spreader? #6
When loading, go easy on what you put up front.
Try to get most of load heap over rear trailer axle.
   / JD HPX Pulling a GD Manure Spreader? #7
An HPX would have no trouble with this spreader.
John M
   / JD HPX Pulling a GD Manure Spreader? #8
I have one that size (Roda 50 bushel) and I pull it with a sportsman 500 in low range. the Polaris does not even know its there.
2011 Kubota M7040SUD 68HP Utility Loader Tractor (A49461)
2011 Kubota...
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
2022 Club Car...
UNUSED Grey Metal Roof Panels (A50860)
UNUSED Grey Metal...
2018 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A51219)
2018 VOLVO...
2008 FORD F750 SUPER DUTY BUCKET UTILITY TRUCK (A50854)
2008 FORD F750...
