Rotary Cutter JD Gyramor 407 Slip Clutch Disassembly
   / JD Gyramor 407 Slip Clutch Disassembly #1
Zipp0
IH 1086
Here is a link to a picture of the components (my 407 is the same) JD Gyramor 127 clutch - Yesterday's Tractors
I need to tighten the clutch as it is slipping too much (and can't move the castle nut (#1 on diagram) and have it stripped down to where I am looking at the clutch plate holder (#7 in the diagram) and discs which are stuck on the shaft and wonder if anyone has advice as to how I can get the discs off?
I have a couple of bearing pullers which I can try (no joy the first time) and I wonder if there is a trick? (before I apply brute force).
Any help gratefully received.
Thx ~ Zip
Now have the clutch off the shaft but the clutch plate holder and castle nut are split - expensive pieces - any suggestions for sourcing?
17604 (A51694)
17604 (A51694)
3 Point Metal 4ft Cargo Carry (A51573)
3 Point Metal 4ft...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2018 FORD TRANSIT T250 CARGO VAN (A52577)
2018 FORD TRANSIT...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A52748)
2021 NEW HOLLAND...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
