JD GX345 engine wont start / dies after starting, runs fine other times
   / JD GX345 engine wont start / dies after starting, runs fine other times #1
Back40Bob
Jupiter FL / Edwards CO
JD 5093E Limited
I suspect i have a problem w/ neutral safety switch - symptoms are engine won't start - getting fuel/air. Sometimes it will start right up, other times it won't. When it does start, it runs perfectly and then will suddenly die - like you got up off the seat. This is why i think i have a problem w/ the neutral safety switch as after i move the brake peddle, it would start. Any thoughts or suggestions would be appreciated.
   / JD GX345 engine wont start / dies after starting, runs fine other times #2
I think the brake switch on these are a simple 2 prong - easy to put the ohmmeter on and see if you can get it to fail. Though not super easy to get at. I don't know how much grass is packed up above there on yours, but worth a look that the linkage allows enough travel to fully engage the switch.
Can you point me to where i would locate the switch? I have searched the online parts schematics and cant find it.
   / JD GX345 engine wont start / dies after starting, runs fine other times #4
Does the engine have a low oil pressure or level switch on it? If so that could be causing the engine to shut off.
   / JD GX345 engine wont start / dies after starting, runs fine other times #5
I'll pretend that I know it is on the frame rail to the rear of the pedal. If you haven't pulled the deck do so and it should be easier to find.
2013 FORD F-650 ROUSTABOUT (INOPERABLE) (A52472)
2013 FORD F-650...
2017 Chevy Cruz Engine and Transaxle (A50325)
2017 Chevy Cruz...
2006 MACK CV713 KILL TRUCK (A52472)
2006 MACK CV713...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
