JD GX 345 Alternator/Generator
   / JD GX 345 Alternator/Generator #1
Madboomer1964
Clinton,Il
GX 345
Was curious to know if a bad alternator or generator would affect the deck engaging.
   / JD GX 345 Alternator/Generator #2
can you elaborate a little more about your problem dont think it would directly affect the deck but if it has any electrical sources that powers up down or blade movement maybe so and welcome to tractor by net
   / JD GX 345 Alternator/Generator #3
It does have a electric clutch doesn't it? If so then sure the charging can affect deck engagement. I have a old 240 with electric clutch that had a engine swap to a twin cylinder B&S and the engine came from a unit that had a manual deck engagement, no electric clutch, and the alternator was only 1 amp and the deck would start disengaging a half hour into mowing (until battery drained down). I had to replace the stator to a 10 amp all is well now. bjr
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2016 Wilson Hopper Bottom Trailer (A50514)
2016 Wilson Hopper...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
2015 DODGE RAM...
2007 KENWORTH T800 DUMP TRUCK (A51243)
2007 KENWORTH T800...
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
