laurencen
Veteran Member
- Joined
- Feb 19, 2007
- Messages
- 1,196
- Location
- saskatchewan Canada
- Tractor
- Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
Hi, just purchased a F725 front mower, have no manual so if its available for download it would be appreciated, it is powered by a Kawa motor and seems prety strong, it needs blades as they are bent up, couple of questions, does the deck stay up, I assume the knob you pull to lift is spring laoded and tirns to slow the decent but should it tyrn all the way to prevent it dropping, next and maybe the new blades will fix, when cutting grass I find it plugs the exit schute, it seems to trap around the bottom bar on the chute and build up, it sure cuts good all I did was sharpen the blades but they are prety bent up.
If by chance the service manual is available in pdf sure would be handy
Laurence
Laurence
