JD couplers?
   / JD couplers? #1
BryanM
Northwest Ohio
John deere 2155, ford 1600
I have recently bought a Jd 2155 and has 1 set rear remotes. I have noticed if I am using an implement such as haybine I cannot disconnect the hose (its a single action cylinder if makes a differance) if its under pressure. I would like to park the haybine in a raised position or disk in a raised position sometimes. Is this normal? is their a quick connect you can get that you can connect/disconnect under pressure?
I was thinking about putting a valve inline so I could turn off the pressure not sure if it will work though?:confused:
   / JD couplers? #2
There are QD's that you can connect and disconnect under pressure, they are usually the flat-face style that's found on skid steer loaders. They are expensive though...
They valve would also work-you would close the valve, then operate the remote to relieve the pressure.
   / JD couplers? #3
I just had another thought about this...
Why not make a mechanical lock that will hold the haybine in the up position, and take the pressure off the cylinder and hoses? This would be the best and safest solution.
   / JD couplers? #4
For a mechanical lock, I have in the past took a section of steel pipe and cut it length wise. Put the section on the exposed rod of the cylinder and then relieve the pressure.
2011 Superior Trailers of Georgia Trailer, VIN # 4M8FZ1629BD000279 (A51572)
2011 Superior...
Lift Gate (A52377)
Lift Gate (A52377)
2000 Volvo VNL Truck, VIN # 4V4N21JF4YN250174 (A51572)
2000 Volvo VNL...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
Tractor Pallet Fork Frame (A51573)
Tractor Pallet...
