JD and HST
   / JD and HST #1
_RaT_
Super Member
Peoples Republic of Northern CA.
Kioti 3510-SE HST
Curious after a post in the HST/Gear comments whether JD requires you to run your HST at full throttle. Does your JD manual require this or mention it. In my test rides on the JD's, I never ran it at full throttle. Partly because I did not need to and partly because it was a new engine and since it was not mine and someday going to be someones, I did not want to in any way damage it. I'm curious as CowboyDoc mentions that you do and it is stated in the manual. I find it odd that JD would require this. Thanks, Rat...
Oh yeah, if it does say this, do you?
   / JD and HST #2
I never said this and you know it. I said other people have said it. I never mentioned anything about John Deere manuals or hst's.
   / JD and HST
From your post
"It's your opinion that you can run your tractor at lower rpms but the manual and other owners disagree. "
Sorry Richard, I took manual as the manual that comes with your tractor not as manual as in gearbox. I wonder why a manual tractor owner would say you have too run your HST tractor at full throttle when they are using a manual. Prior ownership perhaps or just speculation. At any rate, the question still stands.
Do you have to operate your JD HST at full throttle in order for it to work properly or perhaps at all.
Thanks in advance, Rat...
   / JD and HST #4
Rat there are many people in that thread that said the same thing. I was merely pointing out their interpretation of how an hst is to be operated. I was merely trying to answer your question about misinterpretations. The whole hst argument goes this route every time. Since you've asked it does say to run my JD 455 at full throttle for best performance and it is an hst.
   / JD and HST
Silly question, but what is a JD 455. My JD 510 a front deck mower runs at full throttle, it is a gas lawnmower. It runs at full throttle simply beccause that is needed for the blades to cut and develop the lift to get that grass through the chute. It runs fine at less then full throttle when going from point A to point B. The manual tells me to use full throttle when mowing for this very reason. Kind of like my tractor, it uses a 540 PTO that rarely if ever gets that high as the cut is no better at 540 then at 480 to 500 RPM. This means an engine operating speed anywhere from 1800 to 2300 RPM, still well below the 2800 RPM max. On top of that, my peak torque is well below 2000 RPM which works out very well. Rat...
   / JD and HST #6
For what it's worth, I have a JD 4200 with HST. I don't recall reading anything in my owner's/operator's manual about running at full throttle for the HST to operate properly. I'm not saying it's not there, mind you. I'm only saying I don't recall anything about it in there.
I can tell you that my HST seems to operate just fine at whatever throttle level I've used. Obviously, it lugs a bit at the lower throttle speeds on some surfaces, but it works. /forums/images/graemlins/smile.gif
   / JD and HST #7
I suspect the HST and full throttle is same as my ford hydro i had when you run the engine lower on rpm and use high gear throttling it tends to over heat and cause the rear unit to over heat..
   / JD and HST #8
455 was replaced by the X series. It's a 22 hp diesel tractor that's used for a number of things from mowing, snow removal, tilling, etc. It has a three point and you can put loaders on them. Mine is used for mowing, snow blowing, tilling and snow plowing.
   / JD and HST #9
from the 4310 manual on HST operation:
<font color="green"> The range shift lever (A) provides three speed ranges.
The range shift lever is used in conjunction with the forward (B) and reverse (C) travel pedals.
IMPORTANT: Avoid damage! Select the proper speed range for the job.
· The machine may be operated with engine speeds at 950 - 2920 rpm. Within these limits, the engine can be placed under varying load operations.
· Never overload engine by lugging machine at low idle speeds.
· Raise engine speed to match expected loads. If a slight increase in engine rpm occurs simultaneously with moving hand throttle lever forward, the engine is not overloaded.
</font>
Nuff said!
   / JD and HST #10
Rat, your question carried the implication that engine speed should be limited on a new JD tractor. Unlike Kubota, JD does not request that you limit engine speed on a new engine. In fact my dealer said crank it up and let it run, just be sure to let it idle for a couple of minutes before shutting it off to prevent heat build-up.
UNUSED TOPCAT QUICK ATTACH STUMP GRINDER (A51244)
UNUSED TOPCAT...
2021 John Deere XUV835M Gator (A50514)
2021 John Deere...
2020 CATERPILLAR 320GC EXCAVATOR (A51242)
2020 CATERPILLAR...
UNUSED MOWER KING SSB72 BOX BROOM (A51244)
UNUSED MOWER KING...
Case IH 1020 Platform (A50514)
Case IH 1020...
