JD 990 vs Massey 1528
   / JD 990 vs Massey 1528 #1
Rustyrat
Maine
JD 2305 tlb
I am shopping for a compact tractor. I want a backhoe with it. I have been looking at some new (JD 2320 and Kubota 2320) but I am also looking at some used tractors. Used allows me to get a little more tractor than what I really think I need. I am looking at a 2000 JD 990 and JD 8B backhoe with 1100 hours and a 2007 Massey 1528 and MF 1470 backhoe with 166 hours. Both around 17K. Is the older bigger CUT a smarter buy than the newer smaller one? Someone told me that JD never orphans a tractor and that keeps sticking in my mind. Thoughts are appreciated.
   / JD 990 vs Massey 1528 #2
tractors generally aren't throw away items, so you generally need something that is repairable. being able to repair it means you need to be able to get parts and/or service. in today's world, many parts can be mailed directly just as easy as picking them up at the dealer, but there is always that time when you may need advice on something. it's nice to be able to work face to face with someone rather than rely on a phone call. for simple parts is sure is nice being able to pick them up instantly.
in the state i live in, we have 3 massey dealers, and about a dozen jd dealers. i am fairly central in the state and all 3 massey dealers are around 50mi or less away, but for people in the northern part of the state they could be 150mi away. i didn't check, but maybe there are canadian dealers just across the border, but that gets into a border cross and customs issue too, so more hassles.
i can't say for the size comparison on the these tractors, but i'd go with the biggest you can work with. by biggest i mean weight and not power. i think i'd gladly swap a few horsepower for several hundred (or more) pounds of weight. i have a jd770 with a woods 7500 backhoe, and i have uprooted some amazing size stumps - most are far too big to lift after i rip all the roots out, and i have to roll them out of the hole. i often find the biggest enemy is weight. i find times where i will pull the tractor with the hoe before breaking the root. more power never hurt either.
i bought my tractor in 1998, and back then there wasn't a lot available for used. they were generally well worn by the time they were sold, so i ended up buying new. i went with the 770 over a larger one because by the time i stepped up to a 970 or 1070 and went to the bigger hoe, i was jumping from around 20k to closer to 30k for the tractor/loader/backhoe. it was more than i could chew off.
for what i do, the size is fine. i run a 4" hydraulic feed pto chipper, 5' rotary mower, 5' loader, 5' backhoe, and it's generally the backhoe where i find myself wanting more power and size, but then again, even if i had a larger one, i'd just find something too big for that to do too. i think that's going to be the case with any backhoe -they won't do what a 100k excavator will, even though we want them to.
   / JD 990 vs Massey 1528 #3
hello i have both machines 990 and 2320 there is no comparison the 990 is much more of a tractor,the only thing about the 990 is the backhoe is hard to put on and its big it takes up more room than the tractor. i bought my 2320 for mowing witch it does that very well .
2011 FREIGHTLINER CORONADO(INOPERABLE) (A50854)
2011 FREIGHTLINER...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
LEE G550 MOTOR GRADER (A51242)
LEE G550 MOTOR...
P&H OMEGA 20-20 (A50854)
P&H OMEGA 20-20...
2024 Iron Bull 20ft T/A Equipment Trailer (A49461)
2024 Iron Bull...
