JD 990 tractor flashers not working
   / JD 990 tractor flashers not working #1
farminbovina
catskill mountains, new york
John Deere 990
Hello,
the dealer told me to replace the flasher relay (already checked fuse). One person at the dealership told me
I could find the relay by the fusebox under the hood. When I couldn't find it there, another call to the dealer and
was told to remove the cover by the ignition switch and I would find it there. But...I couldn't find it there either.
Any suggestions would be appreciated,
thanks !
   / JD 990 tractor flashers not working #2
I suggest you repost this in the Deere Owning/Operating forum along with the serial number of the tractor.
With a bit of luck, another Deere 990 owner will have a service manual and will be able to help.
The reason for the serial number is the 990 has changed over the years, and that may include the location of the flasher relay. Manuals will apply to serial numbers more so then model years.
Hi Roy,
thanks for this info. I didn't know about the Deere owning/operating forum, so I will post there along with the serial number. Good ideas,
and thank you very much.
Gary (Roy) Robson
   / JD 990 tractor flashers not working #4
hello im looking at my tech manual for my 990 the relay is under the instriment panel above the key to the left sn 590000.
Hello,
thanks for the info. I will check my serial number and look under that panel,
thanks
Gary
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
LOT LOCATIONS (A51222)
