JD 955 Top Shaft Seal leak....
   / JD 955 Top Shaft Seal leak.... #1
fsr2007
JD 955
I've got a bad leak at the top shaft seal. I believe it is called the top shaft seal. It is the seal that goes around the shaft that connects to the "driveline" to the engine's flywheel. Can I disassemble the two bolts that hold the U-joints together and pull out the driveshaft or do I have to move a major component?
Thanks!
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
