JD 955 needs an engine
   / JD 955 needs an engine #1
vollrathm
Marysville Ohio
John Deere
:(My John Deere 955 utility tractor need short block or entire engine if one can be found. Anyone know of used one out there? Its a Yanmar engine modle#3TNV84. This is a 3 cylinder diesel.
   / JD 955 needs an engine #3
If it's a V series engine... then I don't think it's original. I do not believe they ever used the V series in the x55 tractors. The engines that JD used were 3TN84RJ which I believe were of the E series. Not to say that the V wouldn't work... it's basically just an updated version of the same engine and I'm sure it would bolt right in. Just trying to help clarify to help in your search for a replacement block. I don't know how deep your pockets are, but a brand new short block can be had from Yanmar for about $3,200. I just got done rebuilding a 3TNE88 for my 955.
   / JD 955 needs an engine #4
By the way... what is wrong with your current block that makes it scrap?
possibly could rebuild this engine but heavy knocking on bottom of engine now wont start. Though maybe someone could have used engine for reasonable price.
   / JD 955 needs an engine #7
May as well do an autopsy first...
I agree. The old engine has to come out to put another one in... take it out and while you're looking around for another one, take it apart and see whats what.
INSPECTION (A48837)
INSPECTION (A48837)
72in Fork Attachment (A49346)
72in Fork...
Deutz 2WD Utility Tractor (A49346)
Deutz 2WD Utility...
2015 KOMATSU PC360LC-11 EXCAVATOR (A50458)
2015 KOMATSU...
2011 Hyundai Tucson SUV (A48082)
2011 Hyundai...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
