Oil & Fuel JD 955 burning engine oil
   / JD 955 burning engine oil #1
tag01
oelwein iowa
IH 1466, IH 656, JD B, JD 955
I purchased a 1990 JD 955 with 963 hrs back in January. I changed all the oils, filters and fluids before using. In 10 hours of full throttle medium duty work the engine oil on dipstick went from the full mark to the add mark. Is this normal or is it time for an engine overhaul?
   / JD 955 burning engine oil #2
In my opinion, neither. My 755 with 1100 hrs doesn't use any engine oil between changes. But I'd bet you're only down 1/2 quart or so. Just check the oil before each use each day That should be less thn 10 hours, and you'll soon develop a feel for that machine's normal usage.
   / JD 955 burning engine oil #3
I'll add to check the tightness of both the drain plug and the filter.
It's quite odd to go from not using oil, doing an oil/filter change, then using oil.
Look for any leaks...and remember, not all leaks are static.
BTW, are you seeing any smoke out of the exhaust? You can expect some smoke on start up or when there is a sudden increase in load on the tractor, but you shouldn't see continuous smoke.
   / JD 955 burning engine oil #4
Depends on the oil. Cheap oil will evaporate off the light ends and drop the crankcase level. Top the level back up and it will hardly drop for the rest of the change interval.
Thanks for the information, Engine oil is JD Plus 50 ll 15W40. It smokes a little blue during warm but that is normal for any diesel. What concerns me is when I am out mowing in the open yard the exhaust appears clear but when I am mowing up against a building, on the exhaust side, then I can see bluish exhaust. Then when I let it sit and idle while hooking up equipment, 5 minutes or so, then get back on and rev it up it belch's a small cloud of bluish smoke then that dissapears. At first I thought it might be loading up on unburnt diesel fuel, but unburnt diesl fuel is white smoke,, correct?
   / JD 955 burning engine oil #6
Oil consumption alone is not a good indicator of need of overhaul. Does engine have good power? Does it start easily? Do you have lots of blow-by? If oil consumption is the only concern, I would try changing the oil with a different brand. I would recommend 15/40 Deere Torq Gard Plus 50 II, or maybe Shell Rotella 15/40. What oil did you use? I have had customers complain of oil consumption and when they switched to Deere oil, they quit using. Also the previous owner could have used improper oil or because of lack of changing oil, rings could be sticking/ gummed up. A couple of changes with good high detergent oil could free them up. With proper care and maintenance, the engine should last several thousand hours.
Engine oil is JD Plus 50 ll 15W40, has plenty of power, starts great, just a tint of bluish blow by (gotta really look to see it). Never thought of switching oil brands, I will try Rotella 15W40 I use that in my row crop tractors.
   / JD 955 burning engine oil #8
This tractor is new to you?? I would not get excited yet. What had the tractor done before you acquired it? Sometimes they just need to be worked hard for a while. Excessive idling or light loading can sometime glaze the cylinder walls and allow excessive oil past the rings. Usually with that a good work out will slow the consumption down. High oil consumption with little blowby is unusual.:thumbsup:
   / JD 955 burning engine oil #9
I have used both the Deere Plus 50 15W/40 as well as the Rotella T with the same weight. Seems to make no difference in the oil consumption on my Deere 4210. The suggestion that you make a few changes is a good one. Back in the early '70's I purchased a '67 Mustang with a 289, it had an oil burning issue, think the person I purchased it from had neglected taking care of it, I made several oil and filter changes in the next 1,000 miles and the oil consumption problem almost disappeared.
I may be wrong here but to me, it's fine black smoke that indicates unburnt diesel fuel, not bluish white.
   / JD 955 burning engine oil #10
what did you do about 955 using oil bought one with low hours and uses oil like you described wondering what you did thanks
2021 Dosko 337S-13HC Walk-Behind Stump Grinder (A49461)
2021 Dosko...
Ford F-450 Utility Truck (A51039)
Ford F-450 Utility...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2012 MAGNUM TRAILER (A50854)
2012 MAGNUM...
2013 COACHMEN CATALINA TRAVEL TRAILER (A50854)
2013 COACHMEN...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
