JD 950 Starter Problems
   / JD 950 Starter Problems #1
yooperdave
Veteran Member
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
My folks have a 1980's JD 950 which they bought new.
During the past few years, when the key is turned to start the engine, only a single click noise is heard and nothing will proceed to try to start the engine.
We thought it sounded just like having a near dead battery, but that does not seem to be it. Our JD dealer who is known for not servicing his customers could not figure it out either.
Yesterday, I tried the key several times and finally got thru to the starter to turn the engine over to fire it right up.
This problem has gotten worse over the years. The tractor could have been running for 6 hours, turned off, and then would not start right after.
Any suggestions or some different tests to try to diagnose?
Thank You
Yooper Dave
   / JD 950 Starter Problems #2
The first thing to do is to clean the battery cable connections. Both at the battery and at the other end of each. This is the typical symptoms of a bad connection. Get a battery brush tool at you local auto parts store. They have a small brush to clean the inside of the clamp and a cup brush to clean the battery posts. If that doesn't solve the problem, take the battery to the parts store and let them test it on their battery tester.
   / JD 950 Starter Problems #3
Ditto on the clean connections. Does this tractor have any safety switches that could be disconnected or faulty? If the current is getting to the starter(after cleaning all connections) and still does not start, try jumping the starter, that will tell you if its the solenoid which is a whole lot cheaper to replace than the starter. If you are getting current from the battery to the starter but not the solenoid, the problem may be in the starter switch itself.
   / JD 950 Starter Problems #4
My 1050 does exactly the same thing. Has for years. I even tried another 1050 at an auction and it did it too.
Maybe it'll crank on the first try, maybe the 10th, maybe the 50th. It always starts after it cranks. I took off the starter and carried it down to a local auto electrical guru and he claimed there was nothing wrong with it on the bench. There wasn't either. He jumped a terminal more than a dozen times to prove it.
Somehow, the thing isn't getting enough juice to activate, or it's bypassing itself somehow. I've cleaned every connection I could find. inspected everything I could find, even the little black box behind the dash.
I still suspect the starter, as the replacment looks nothing like mine based on the parts book.
If you all learn anything about this snafu, please post it.
I should add that the 950 and the 1050 share the same engine. The only difference is the 1050 is turbocharged.
   / JD 950 Starter Problems #5
Your description of the problem leads to either not getting enough current to the starter (bad connection), a bad solonoid or a starter that is drawing excessive current.
As others have mentioned, remove and clean ALL connections at the battery, starter and the ground to the frame.
You can jumper across the solonoid to see if the starter will turn.
As bushings wear in the starter there is more free play between the armature and the field coil shoes. This can get bad enough to cause excess friction which requires more current to overcome. You could also have a problem with brush wear at the commutator end of the armature.
Jeff
   / JD 950 Starter Problems #6
<font color="blue"> took off the starter and carried it down to a local auto electrical guru and he claimed there was nothing wrong with it on the bench. There wasn't either. He jumped a terminal more than a dozen times to prove it.
</font>
ScottAR,
A bad or marginal starter may still "test" OK on the bench. There is no load on the starter. In the tractor when the starter drive gear engages the flywheel, the load on the starter will require more current. If the starter is worn it may not be able to overcome its own internal friction or electrical resistance.
Jeff
   / JD 950 Starter Problems #7
Scott - Just curious. I have never had a problem one with my 950 (except the one time I left my key on and ran the battery down /forums/images/graemlins/blush.gif). The click Yooper Dave speaks of indicates he has enough current to pick up the solenoid (very little current required) but not enough to turn the starter ( a lot of current required). Does yours also do the clicking bit? Or nothing at all?
The starter was replaced with new at one point, but it did not solve the problem.
How hard is it to bypass the "idiot switches" on this tractor?
I agree that once the starter deceides to engage the engine, it will fire right up.
Yooper Dave
   / JD 950 Starter Problems #9
The one for the PTO would not be hard. There is also one where the H/L lever must me in neutral. That one may be harder. However, since you hear a click of the solenoid, I don't think these switches are your problem. The solenoid may go thru these switches but not the starter motor. Do you have a schematic/wiring diagram of the starting system? I do but it is 30 miles away where my tractor is. If I make it up there tomorrow, I will try to remember to look at the circuit.
   / JD 950 Starter Problems #10
Yes, the solenoid clicks, That's when I know to keep trying. /forums/images/graemlins/blush.gif
I've been mulling over replacing it since a new one wasn't that high when I last checked. (under $100 if I remember)
2004 JOHN DEERE 5320 TRACTOR (A51243)
2004 JOHN DEERE...
Unused Delta Crash...
IH 445 Square Baler (A50515)
IH 445 Square...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
Fireplace Mantel Wooden Corbel (A49462)
Fireplace Mantel...
2025 LandHonor Hydraulic Vibratory Plate Compactor Skid Steer Attachment (A49462)
2025 LandHonor...
