Dirtdigger5
Had some blow-by on my Yanmar engine at 1500 hours. Took it to the local JD Dealer and they did a compression test that showed about 430 psi. The service manual says that normal compression for this engine is from 560 to 639 psi with no more than 25 psi among cylinders. It recommends that an engine job be done when the compression reaches 426 psi. They did not do a wet/dry test to see if it was the valves or the rings before they started dismantling the engine Dealer changed cylinder liners, rings lower bearings and sent the head out to have the valves done. When I got it back it was still blowing-by so I took it back to them and had them re-do the compression test. They got around 440 psi on all cylinders. They put it on a dynamometer and ran the tractor for several hours. The blow-by stopped but the compression never improved much. They told me that there must be a misprint in the technical manual that I bought years ago as 560 to 639 psi was too high for a small diesel engine. Has anyone done a compression test on a newer 950 and recorded what that was. I never did a compression test on this machine when it was new so I have no way of refuting them. I have put about 50 hours on the engine since I got it back and it blows a lot of white smoke when I throttle up after the machine has been idling a while. I still have the break-in oil in it that was put in during the winter so that may be a contributor.
