JD 950 backhoe
   / JD 950 backhoe #1
TimberHole
Platinum Member
Missouri
JD9504WD w/ 75 Loader, JD345, Bobcat S150
Anyone have a backhoe on a 950? Research shows a JD model 8 hoe. I would like to get some additional information on this setup. I am also thinking a JD8A works as well. I am wondering if these hoes use a PTO driven pump or use the tractor hydraulics. Also would like to get some info on the subframe and how it attaches to the tractor. I am thinking this might be a fairly easy frame to make if need be but maybe if I saw one I would think differently.
   / JD 950 backhoe #2
Most folks with a mid-level metal fab experience and a shop with equipment could make the frame all right. I understand that the 8a difference is only in the boom swing setup and otherwise is identical. I had both tractors at the same time before I sold off the 950 and was considering making the frame to mount the same #8 hoe on either tractor. Got a offer on the 950 I couldn't refuse and sold it. Guess I'd consider the job if I had the ability to purchase a #8 hoe at a reasonable price. The ones I've seen for sale were in the $2500 range in this area. The path I choose was to upgrade to a 970TLB with the #8 hoe and mount as part of the deal and have never regretted it. Good price from the 950 paid for most of the trade. 970 you can shift on the fly, has a 4 cly engine that is smother running, easier operator station to get into and out of. My employer had a Kubota L35 in the same HP range that I thought had a little more guts in the backhoe boom. More money to purchase though. Lucky to have run a 3 point mounted hoe of the same size for reference and from that experience I can say for sure the strongest setup is the frame mount. Lots of my choice was the chance to make the trade that came along, luck. Torch set, welder, metal cut off saw, the ability to heat and bend steel, not to tough of a job. One thing for sure is that JD made plenty of #8hoes.
Chris
   / JD 950 backhoe #3
Did this research involve the online parts book on the JD site ?
   / JD 950 backhoe
Yes it did. I’ve been in that parts book a time or two. I was hoping I might find someone here that could give me some general and possibly some photos showing how the subframe mounts.
   / JD 950 backhoe
Chris
Thanks for the info. The subframe looks pretty simple but I知 a little unclear on how it mounts to the tractor. I saw a Kubota hoe for sale recently and it got me wondering about making the subframe to support either a 8 or 8A or even another brand. If I知 seeing it correctly the 950 frame looks much more simple than other frames.
Does the 8 or 8A run off the tractor pump or does it have a seperate PTO driven pump?
   / JD 950 backhoe #6
Runs of the tractor pump. The 970 has what looks like a 2 stage or double pump. The 950 uses the standard Yanmar front mounted pump. I think the difference will be the speed of the hoe, with the 950 being slower. This you should be able to look up on Tractor Data.com with the flow rates.
Chris
FAKE (A52472)
FAKE (A52472)
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
