JD 855 with no electrical power
   / JD 855 with no electrical power #1
edwardsss
Ramsey, MN
John Deere 855
Hi All,
I hoping someone has had a similar issue as I do with my John Deere 855. I've owned the tractor, without troubles, for about 10 years and there are about 800 hours on it on the meter. I drove the tractor out of the garage, starting it without a problem, and after a brief warm up then shut it off to refuel it. Next, I turned the key to start it, the starter began to turn over then I heard a click and all power went away. All power to the dash panel is gone, no lights, etc., no matter the switch position, and the starter will not activate. Flat out there is no electrical power. I have 12.5 volts to the ignition switch, and the ground wire to the ignition switch is good too. All of the fuses are intact. This tractor did not require the operator to be in the seat to start the tractor.
Has anyone else experienced this problem, or can you give me some idea where else to look for the break in the power?
Thank you,
Ed
   / JD 855 with no electrical power #2
Clean the cable connections to the battery and at both ends.. may just be corrosion.
Then evaluate the age of the battery.. if 6 or more years, I'd replace it with new (or at least get it load tested).
After that, see where you are at.
:welcome: to TBN
   / JD 855 with no electrical power #3
Yep, clean the battery terminals. Also clean the ground cable where it attaches to the frame and go from there. It's quite amazing how much contact surface area you can have but no electrons getting through.
   / JD 855 with no electrical power #5
Yep, cleaning things up is your first step. You can measure correct voltage with a meter, but if there is enough corrosion upstream, as soon as you put a load on it (like turning the key), it will drop, sometimes to near zero.
In fact, you might want to try that. You might need a helper to turn the key, but at the same place where you measured 12.5 volts, hook up your meter and turn the key. I"m betting you'll see the voltage drop like a rock. If you do, either your battery is shot internally, or you have some bad corrosion in your battery cables somewhere.
Thanks for the direction to take. I will try it.
   / JD 855 with no electrical power #7
Hi All,
Thank you,
Ed
Does that include the fusible link?
Also, you have THREE system grounds to check on an 855...not counting the battery ground...:)
View attachment john-deere-655-755-855-955-756-and-856-compact-utility-tractors-technical-manual.pdf.pdf
Yes, it includes the fusible link. According to the starting circuit shared, the fusible link is a red power wire that connects to the "bat" terminal on the switch. I am getting voltage at that point. I'm not getting voltage past the switch to light up the dash panel.
I followed your advice. Pulled the terminals. They were still clean from a couple of months ago, but I cleaned them again. As I was reminded by another person, 12.5 volts is not a stellar battery. I replaced the old battery with a new Legend battery from NAPA, and the 855 came back to life.
Thanks again for all the help. I really do appreciate it.
Ed
   / JD 855 with no electrical power #10
:thumbsup: :thumbsup:
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2004 Kubota L4630 (A50123)
2004 Kubota L4630...
2017 HINO 338 BOX TRUCK (A53426)
2017 HINO 338 BOX...
2016 Kia Cadenza Sedan (A51694)
2016 Kia Cadenza...
