Tractor Sizing JD 855 w/72" MMM - 24HP OK?
   / JD 855 w/72" MMM - 24HP OK? #1
Gl33kl
Midwest Ohio
JD 3010
Looking at an 855 w/70A fel, mfwd, 750hrs & a 72"MMM. Low hours and priced right, but I'm a little concerned about the 72" deck with the 855's 24HP, vs the 955's 33HP. Going to use this for a lot of mowing and don't want to be undersized for the times when grass is growing like mad and spring rains prevent mowing... Have really been looking for the 955 but they're harder to find and prices are sometimes crazy. Comments appreciated, Thanks.
Greg
   / JD 855 w/72" MMM - 24HP OK? #2
That machine will have no trouble with a 72" MMM.
   / JD 855 w/72" MMM - 24HP OK? #3
Agree with Kennyd...
Worst case is you'll have to run slower or take partial width passes if the grass is tall and thick (or wet). Do keep your blades sharp!
Nice tractor, the 855!! That was the first compact tractor I operated and is what got me into buying a CUT for myself.
Thanks for the feedback. Will be looking at this Friday or Saturday and be sure to post a trophy shot if it works out.
   / JD 855 w/72" MMM - 24HP OK? #5
Good luck...and don't wait too long.
Good tractors at good prices sell fast.
   / JD 855 w/72" MMM - 24HP OK? #6
Hoping that worked out for you.....I have a 72 MMM on mine and it will cut grass thats taller than the hood as long as I take it a lil slower. Its a mowing machine...I cut my 5 acres with it like i said as tall as the hood and when i went over it a second time it wasn't even win-rowed....looked like my yard my MMM cuts as good as my zero turn!
2011 Kubota L3200 (A50120)
2011 Kubota L3200...
Hydraulic Lift Platform (A50121)
Hydraulic Lift...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
3pt Fertilizer Spreader (A50120)
3pt Fertilizer...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2005 Pierce Enforcer Special Operations Fire Truck (A50323)
2005 Pierce...
