JD 855 Fuse Block
   / JD 855 Fuse Block #1
DudeJohnDeere
Walworth, NY
1940 Allis Chalmers B, 1992 John Deere 445, 1998 John Deere 855, 2001 John Deere SST18, 2007 John Deere Gator TX and many others at the farm yard
I have a 1998 John Deere 855. I have to replace the fuse block on it as one of the sockets is messed up. In order to access the wiring, I have to remove either the fuel tank or the dash, and I would prefer to remove the dash since I just filled it up with fuel. If you guys have any tips on removing the steering wheel and the dash on the tractor, that would be greatly appreciated. I should be able to handle the wiring without any troubles as I've done a lot of electrical work in the past. Thanks for the help.
   / JD 855 Fuse Block #2
Dude..
How did you come out on this problem? Fixed?
Didn't illicit much help, but assume you figured out something.
   / JD 855 Fuse Block #3
My thought is I'd go the easy route. If just one socket messed up I'd clean and flux what's there then solder a pigtail fuse holder in place, use same amperage fuse.
2021 Simex padding bucket, 8-9 ton class, like new (A52384)
2021 Simex padding...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2020 KUBOTA RTV...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2025 IR UNUSED Hydraulic Breaker (A53117)
2025 IR UNUSED...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
