Does the tractor have turf tires or ag? I have found that the ag tires steer easier than the turf tire when you have no power steering. Either way the steering is definitely going to be stiff with a load in the bucket. As rolltide says, if you don't know any different, you can cope OK if you learn to steer only if you are rolling. steering while sitting still will be near impossible. Power steering on these tractors was a field installed option, so it would be possible to add it on yours if a kit could be located. I think that deere no longer sells the kit, but you might find one at a junkyard to buy the components. Good Luck!
