JD 850 current value
   / JD 850 current value #1
nickel plate
Veteran Member
CA
2002 New Holland TC40S
I got a call from a friend of mine who's father passed away awhile back and owned a John Deere 850 which he purchased new as a harvest rental return with 20-30 hours on the meter and used very little since then. He is not looking for buyers, just a fair market value. Sorry but no photos are available at this time as the tractor is stored in a shed on a remote ranch but I can say that it starts right up and behaves well as I drove it last year for a couple of hours doing dump runs and post hole digging with no issues. I think the reason for such low hours is that the owner also had a Cat D4 and D6 at the ranch.
199 hours on the meter
All sheet metal is straight with no dings, fenders are perfect
Subminimal surface rust
Paint does not appear to be faded but does have an aged patina
All decals in place
No power steering (I don't know if it is broken or not equiped-I would go with the latter)
No cracks in the steering wheel
2/4 wheel drive
one piece ROPS
One small crack in the seat upholstery
High/low eight forward two reverse
Clutch and rest of the drivetrain seems excellent (no oil leaks)
All electricals work
All gauges work
JD FEL (there are implements but for the sake of pricing, let's just keep with the tractor and FEL)
Hydraulics are instant and strong
No remotes
Alternator
A new JD battery will be installed on the next ranch visit
Tires are 80% rear and 60% front
No idea on service records
At this point I can't furnish the year purchased
I think the used car people would refer to this tractor as a "creme puff"
Thanks in advance and just for the record, I own a 2002 NH TC-40 with a FEL, Woods backhoe, Gearmore BB, York 8' rake, Wallenstein BX40 chipper and a custon built hyd log splitter.
   / JD 850 current value #2
There are 20 850 tractors listed on tractorhouse.com .....some with loaders....some are two wheel drive and some are 4x4. Hours vary allot. Seems they can run from about 4500 to about 10k.....depending on condition, etc. Have a look.
I would question that an 850 4x4 could be bought without power steering. Sounds like it must need some work (?).
Patina huh?.....lol.....sounds like fine art. (grin)
Hello foggy, for sure on 4x4. I remember shifting in and out of FWD as the ranch is quite hilly to steep. Yeh, patina...that nice aged sheen that makes an older JD a piece of tractor fine art. Thanks for the .com lead.
   / JD 850 current value #4
actually, alot of the 650, 750, and 850 with mfwd didn't have power steering. If you can figure out why, let me know!! Should have been mandatory on a mfwd...on all of them for that matter....
   / JD 850 current value #5
Power steering, like hydrostatic transmissions, wasn't too common before the mid 1990's. Probably wasn't too much demand for it, especially in 2WD machines.
   / JD 850 current value #6
The older cuts didn't have enuf hydraulic power for a loader and power-steering so you got to pick what you wanted.
2009 HINO 185 18FT BOX TRUCK (A45679)
2009 HINO 185 18FT...
2008 CATERPILLAR CB434D DBL DRUM ROLLER (A50458)
2008 CATERPILLAR...
More info coming soon! (A46683)
More info coming...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A50459)
KNOW BEFORE YOU...
Polaris Ranger 4x4 Utility Cart (A49346)
Polaris Ranger 4x4...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
