JD 80 FEL Repair
   / JD 80 FEL Repair #1
wsp617
Wisconsin
JD 1070
I just bought a JD 1070 with a 80 FEL. It works fine other than the holes for the pins (especially where the bucket pins are) are starting to get "egged-out". I was wonder if a guy could weld on a bushing and then use a longer pin.
Also, does anyone know the difference between a JD 80 FEL and the 440 model. I see them both on the 1070 units.
   / JD 80 FEL Repair #2
Which bushings are sloppy ? Those in which the pins are fixed, or those in which the pins pivot ?
I replaced all bushings of the Veto FX12 loader i bought a few years ago, when i rebuilt it, added self levelling, quick attach.
Those were standard slide bearing bushings, of which i found the ordering number from the SKF website, then called an industrial retailer, which sold me the equivalent bearing from their supplier.
If its the slide bearing bushing, you can easily replace it. if its the fixed bushing, welding on a new one would definately be cheaper than having one of those mobile machinists come around to weld them from the inside and then machine back to original dimension. http://www.mobielkotteren.nl/index-english.htm
Caterpillar 308E2 CR Midi Excavator (A52377)
Caterpillar 308E2...
2016 Ford Escape SUV (A51694)
2016 Ford Escape...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51691)
2014 International...
2008 CHEVROLET C7500 SERVICE TRUCK (A51406)
2008 CHEVROLET...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2015 FORD F550 UTILTY TRUCK (A51406)
2015 FORD F550...
