Backhoe JD 790
   / JD 790 #1
digger28
Harrisville
2003 JD 790
This is a question that's been asked in past years, but I'd like to get some fresh feedback on
backhoes for a JD 790. So...
Which is preferable 3-pt or frame mount?
I've found four manufacturers so far: JD #7, Woods, WoodMax and Liberty?
What have you found to be both reasonably priced, durable, functional and a good fit?
Is a thumb worthwhile?
Any suggestions will be appreciated!
Thanks-
   / JD 790 #2
Frame Mount is better than 3pt mount, JD no longer has the JD #7, I tried to find one a while back, and my dealer also said he couldn't find one, there are a few now again up for sale used. I ended up buying a new Woods BH70-X, looks way better than the JD BH, has a good frame mount, and got a mechanical thumb, cheaper than if I'd found a JD BH. Rosseels Farm & Garden Supply, Inc. had the best prices, customer serivce was great, included shipping right to my driveway, and it was painted green!
   / JD 790 #3
I'd only put a frame mounted backhoe on my 790. The 3pt hitch of the 790 was not designed for the lateral forces generated by a backhoe. My :2cents:
   / JD 790 #4
is the hydraulic pump big enough on the 790 to run a BH or does you need a power behind/beyond kit as well??
   / JD 790 #5
Power beyond on a 790 is mainly for running a backhoe. I have looked at several and personally like the Woods BH70-X. There is a sub-frame available for the 790 and it hooks up to power beyond. The JD #7 backhoe ran off of power beyond and was an option for the 790.
2011 New Holland B95B Cab MFWD Loader Backhoe (A52128)
2011 New Holland...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
E-Z Trail 675 Grain Cart (A50514)
E-Z Trail 675...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
