cabover4us said:
RobS
I was reading your post, and you got me interested in knowing the steps in removing your #7 backhoe. I have a #7 mounted to a 855, havent used it much at all, bought it last fall late in the season, my son dug a three foot hole just to try it, no effort at all...
greg
OK, I'll see if I can remember the steps:
1) Back up to wherever you want to leave the hoe. Level and smooth is good.
2) Lower the boom to the ground to unload the top link and remove the top link pin at the tractor and the pin halfway along that link. With both pins out you can flex the link to fold it up and out of the way. I put both pins back in to not loose them.
3) Raise the boom back up a bit to unload the subframe. Pull the pins at the front of the subframe, under the operator platform. Mine are spring loaded but the 855 may be different.
4) Lower the stabilizers and the boom to put the whole weight of the hoe on the ground. Now the trickiest part, work the boom and stabilizer controls to lower the front of the subframe and keep the rear subframe mount at about the same height. Do this from beside the hoe, not on the seat. You'll move the boom down to lower the front of the subframe, then tweak the stabilizers some. The subframe will end up at an angle, lower in front than the back. Also, the hoe seat will rotate forward and probably hit your tractor seat.
5) At this point, you can pull the tractor forward a few inches to clear the subframe but not stress the hoses. Take a good look at the rear subframe mount to the tractor, below the PTO. This is what it needs to look like when you hook back up.
6) With the tractor clear, lower the hoe to the ground using the stabilizers and boom contol. Watch the hoses though there should be enough slack.
7) Once it's on the ground and steady, shut the tractor off and disconnect the hoses (have a good look at the routing before unplugging). Plug the tractor end back into the tractor and hook the two hoe hoses together. It is most important to plug the tractor hose back into the tractor otherwise you dead-head the hydraulic pump.
8) Restart the tractor and pull away.
9) Remove the strut that keeps the rockshaft arms up and put the tph hardware back on (this can be harder than you think due to the subframe bracket below the PTO, it obstructs the tph hardware some).
10) Installation is essentially the reverse. The rear subframe mount has some clever stops built into it that help guide everything back together.
I've got this down to the point that I actually keep my hoe on my tractor most of the summer, so it can be in the garage. I pull the hoe off everytime I need to use a tph implement. With practice it literally only takes five minutes. On the other hand, if you don't get things lined up pretty well, it can take quite a bit longer with plenty of adult words to help!
