JD 790 vs. NH TC30
   / JD 790 vs. NH TC30 #1
Hosskix
Bronze Member
Midland, Texas
JD 790
My local dealer quoted a 790 with a FEL and boxblade for ~15000.
I found a dealer about 4 hrs from me with a TC30 and FEL for the same price.
I'm kinda torn between the 2.
Part of me says "Go green", the dealer is closer and I haven't read many complaints from owners about this tractor.
Plus, I use to live on a ranch that had a 770 that I used all the time, so I'm use to the controls, etc.
On the other hand, the New Holland has more horses, more gears and weighs a little more.
I've heard a few complaints, but most of those seem to deal with the "higher end" NH's and not the stripped down version I'm looking at.
The main problem is the dealer's location.
We've got a local dealer, but I've met the sells rep and didn't really care for him (plus he quoted me 17K, I'll drive 4 hrs to save $2,000!) and I've also had dealings with their parts dept before, (not particularly helpful), so I feel that I may have problems getting service from them if I don't buy the tractor there.
Anyone have anything helpful to add to assist me with this painful decision?:p
   / JD 790 vs. NH TC30 #2
Its interesting to see how many folks here stress the value of the dealer. Frankly, after I have purchased my tractors, the need for the dealer was almost non existent, I'm either lucky or the things I have done are things many folks would never tackle. I have driven the JD 790 quite a bit. Its about as basic a tractor as they come. The loader is on the smaller side. The tractor itself is pretty cramped for me. If the NH is larger, that would be my choice, the cockpit on the 790 is just to tight.
   / JD 790 vs. NH TC30 #3
I own both, but they are several years old now. The plus on the JD is just hit the key, with "instant starts!" (DIRECT INJECTION ENGINE) It is a 2000 purchase with the 91.5 cu.in. engine. The tighter turning radius is plus, also. The TC-30 ouality may not be as great, but the additional gears are sure nice for expediting your work! Also, the exhaust on the Deere becomes an issue, if you work around any trees. Access is tighter on the JD, but I solved that easy; when leaving the tractor, I just throw my right leg over the steering wheel! Maintenance wise, the JD will start surging with the slightest of lugging, and I was told by the dealer; "it's the nature of the beast," the NH I've replaced the water pump, after six years, and 500 hrs. Good luck, and a good dealer is also an influence on the purchase.
   / JD 790 vs. NH TC30 #4
For the same price, I'd go with the TC30. It's just more tractor. And a very reliable one at that.
Andy
   / JD 790 vs. NH TC30 #5
A couple of other points on the selection, the JD also has a weaker three-point, and the Model 70 loader struggles with 800#. You are getting more tractor with the TC-30; I would, "go for it!"
   / JD 790 vs. NH TC30 #6
I bought the TC30 did not like where the JD gear shift was and I paid less for my NH than JD so for no problems 200Hr. The only thing I would change I wish I went Hydro.
   / JD 790 vs. NH TC30 #7
I agree 100% about the dealer...
I buy used stuff and do my own maint...
Dealer support for me is only for parts, not reapirs...
If you can't wrench at all then dealer support is more important...
Now...
As far as comparing both tractors...
Both are quite capable...
Not a lot of difference in either...
Try both out and go with the one you like best...
   / JD 790 vs. NH TC30 #8
Now...
I totally agree with you gentlemen about the dealership, when I signed for the JD 790, including on the contract was a 60" bucket. I was out of town for a week during delivery, and my sons in their late 20's didn't notice the 54" bucket. The relationship with the dealer went down hill, eventually ending in an abyss. He claimed we should have noticed the small bucket, and not used it, till it was switched? There was other issues about the engine bucking and surging, which has left feelings, when they stated; it's the nature of the beast? So a good dealer is somewhat important upon initial purchase, and I also do my own wrenching!! "BUYER BEWARE!!"
   / JD 790 vs. NH TC30 #9
Get the 790. Some people are fixated with the number of gears they have. This is not a sports car where you run through the gearbox from 1-12. You will most likely end up using at most 3 or 4 of all the various gears. You will find the few that suit your needs and terrain. A 790 is old technology, but bulletproof. If you have been reading TBN for long, I doubt if you ever saw a single post about "issues" with a 790. That can't be said for a lot of other tractors in the same HP range. Go sit on one and see if it fits you. Better yet, take some measurements to see if it fits your garage or storage shed.
If you end up leaning towards the 790, I will send you a laundry list of stuff to ask for before the deal is done and things to buy at initial purchase. A 790 may not be glamorous, but it is a solid perfomer that costs about $1.40 per hour to run and will do anything a bigger tractor will if you have patience and more time. Mine is excavating a hillside for a house on a mountaintop. I am almost done. The local contractors all wanted $8-12K to do the work just for the initial clearing and driveway. My little 790 is going to finish the job in about 45 hours engine time. I figure it will almost pay for itself one just for this one home site. When I am done, I will then have a low hours tractor that will last another 50 years. My grandaughter can pass it on to her kids........
   / JD 790 vs. NH TC30 #10
GORDON 21: I have a 2000 JD 790, and also a NH/ Ford, which is what the Tc-30 is, a carrier over to NH after the buyout of Ford around the turn of the century. The JD 790 is a great tractor, but in some cases, working with it instead, of the TC-30 can be time consuming. I was building a rather narrow 600' driveway, which required moving and grading base rock in one direction only. The Ford was the answer, because of the two slow "reverse speeds" of the JD. If the JD was used for the job, it would require two turnarounds, one at each end, disturbing your grading, plus the wasted time. The third reverse gear in the Ford made the job much faster, by simply backing up at a comfortable speed, which required spreading eighteen yards of rock. In other confined areas that I work, the JD outshines the NH. Just my opinion?
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
71055 (A49346)
71055 (A49346)
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2017 RAM PROMASTER 2500 CARGO VAN (A51222)
2017 RAM PROMASTER...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2012 John Deere 7280R MFWD Tractor (A51039)
2012 John Deere...
