JD 7810 with Krone baler
   / JD 7810 with Krone baler #1
dgl24087
Veteran Member
Va/WV
1975 John Deere 1530
Saw this combo sitting in front of dealership when I went to check on my new S240.
The baler weighs 25000 lbs, makes a 4 ft by 3 ft square bale and requires 250 hp to operate. The 7810 hooked to it is on the dealer lot and was the only tractor they had that would pull it off the trailer used to transport the baler from the farm.
   / JD 7810 with Krone baler #3
Much more than that.
My Big Pack 4x4 weighs 34,000lbs.
You’d want an 8000 series Deere just to keep that thing under control. Not so much a HP thing as a weight thing. You want a 25,000lb tractor to feel like the Krone baler isnt throwing you around.
Im running 300HP in front of mine in my MX-270 and its fine, but I wouldn’t want to run under 250PTO unless flat ground. Its also a really heavy tractor.
Heck my Hesston 4910 is close to 24,000 with 2 biscuits in the chute.
   / JD 7810 with Krone baler #4
Good post for the TBN JD AG tractor forum ?? Maybe the admins will relocate this thread.
Takes a lot of big equipment to lay out the hay crop to feed this beast. Big stuff for Big farms.
2015 Isuzu NPR-HD Flatbed Truck (A51691)
2015 Isuzu NPR-HD...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
Bush Hog 20' Mower (A50123)
Bush Hog 20' Mower...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2020 KUBOTA RTV...
