JD 755 WHAT TILLER SIZE?
   / JD 755 WHAT TILLER SIZE? #1
stallardt
Could you please give me advise on what tiller size and will any single bottom plow work for this tractor, thank you in advance for your help.
Tracy
   / JD 755 WHAT TILLER SIZE? #2
Prolly a 48" tiller for the hp that you have. But others may a better idea what their 755's handle. I run a 60" on my 32 hp 4300 no problem.
As to single bottom plow, when you ask about "any" single bottom, that is too broad and loose to make a comment. A 3 ph one bottom should fit as you have Cat I hitch. Some adjustments may be necessary, and tires and weight distribution will be a factor for success. What type of ground you plan to plow will also enter in the equation.
But I don't think you can just buy "any" single bottom plow and expect it to work on the 755.
   / JD 755 WHAT TILLER SIZE? #3
I've been looking for a decent used tiller and see a LOT of 48". In theory I'd need wider than that to cover tracks on my 4310 though. Is there a way to offset a tiller somehow to get behind a tire?
   / JD 755 WHAT TILLER SIZE? #4
Most well built tillers either have an adjustable offset or has been built so the mounting brackets are offset so you can position the tiller behind one tire. I think narrower tillers (48") generally have the brackets offset from the manufacturer. I had a JD 55" tiller that was adjustable.
   / JD 755 WHAT TILLER SIZE? #5
I would recommend a 48" tiller for your tractor, something like a Deere 647 or King Kutter II comes to mind. Either of these will allow you to till about seven inches deep. You might pull a single small plow but am a little leary of the results you could expect, think a good tiller is the way to go.
   / JD 755 WHAT TILLER SIZE? #6
I agree with Steve on the tiller. I have a JD 647 and it works great with my 2520. Not sure how well a plow would work with a smaller tractor.
   / JD 755 WHAT TILLER SIZE? #7
"I've been looking for a decent used tiller and see a LOT of 48". In theory I'd need wider than that to cover tracks on my 4310 though. Is there a way to offset a tiller somehow to get behind a tire? "
I have a John Deere 450 tiller (48") that I first bought when I had a 455 and kept when I upgraded to the 2210.
After buying my 4310 I thought I'd get by with it only covering one track until I could find a decent used 60". To my suprise, it works really well behind the 4310. It covers both tracks, barely, but it does! Sure I could handle a bigger tiller, but the 450 hasn't been the problem I thought it would be.
Kind of disappointing actually. A local dealer has a hardly used Land Pride reverse rotation 60" that I wouldn't mind having, It's just hard to justify seeing as the 450 does so well.
As for the 755, I'd stay with a 48". Better to have a smaller tiller that you have the power for than a bigger one that struggles. Being able to keep the tine speed up while digging deep will do a better job on the soil.
   / JD 755 WHAT TILLER SIZE? #8
We have a 60" Kubota tiller that Dad used behind his 755 and he said that it worked great. Had to go slow, but it worked great.
Aaron Z
Thank you so much for your information!!!
Tracy
2004 Honda Odyssey Van, VIN # 5FNRL189X4B025339 (A51572)
2004 Honda Odyssey...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
Peacock Lawn Art (A50325)
Peacock Lawn Art...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
