JD 755 Three point hitch drops extremely slow when warmed up
   / JD 755 Three point hitch drops extremely slow when warmed up #1
Moukie
John Deere 755
Good morning,
well i finally bought a box blade and reserved myself some time to work with my project tractor.........i am the one who sturggled with a list of issues, most notably low oil pressure and non-working mfwd. Well, those are now successfully corrected thanks in part to advice from you all. i tried to use my new box today but found that the 3 pt takes an extreme amount of time to drop, but only when tractor is warmed up well. Works great when cold. Takes about 2 minutes to drop when hot.....?
i have turned the adjustment valve/handle in/out several times and it does not improve. i was hoping that would be it, but no luck.. Turning the handle all the way in does indeed prevent the lift from dropping at all; hot or cold.
i did change hydraulic oil and filter and used jd oil and filter. Dealer sold me hy-gard regular, stating that regular and low vis were both approved and regular was about $10 cheaper.
Does this sound like an oil quality issue or possibly something else? I have had 3pt hitches that would not go up, but never one that would not drop?
BTW - this is the first i have used the tractor so i have no clue if it did the same thing before i changed oil and filter..
Any thoughts as to why the 3 pt hitch will not drop when hot? Works perfect when I first crank the tractor, but gets progressively slower (on the drop only) the warmer the tractor gets. Finally, after about 20 minutes of use, I might as well shut down and quit trying as it takes several minutes for lift to go from up-to-down with the weight of a HD box blade on it.
Thank you,
David in SC
2009 PETERBILT 340 (A50854)
2009 PETERBILT 340...
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
2016 PETERBILT 587 (A50854)
2016 PETERBILT 587...
2012 GROVE TMS900E TRUCK CRANE (A50854)
2012 GROVE TMS900E...
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A51222)
2020 VOLVO...
91013 (A48082)
91013 (A48082)
